Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 08-10-2007, 10:25 AM
Malipoopoo Malipoopoo is offline
99 Malibu tranny probs
My 99 malibu with 118000 miles just started having tranny probs after coming back from my local shop. Now when I shift from park to drive, it slams. Then 1 -2 shift slammed too at first, but now just hits a little hard. Other shifts seems to be smooth, but the P to D really slams hard. Any ideas?
Old 08-10-2007, 11:39 AM
slls slls is offline
Re: 99 Malibu tranny probs
What was done at the shop? Check to see if the IAT sensor is disconnected, "Intake Air Temp". It should be attached to the hose going from the filter to the throttle body. Being unhook will cause this problem.
Old 08-12-2007, 07:24 PM
New thermostat installed. The IAT is connected.
Old 08-14-2007, 08:00 AM
Speedy_1234 Speedy_1234 is offline
Send a message via AIM to Speedy_1234 Send a message via Yahoo to Speedy_1234
Wait...... Check the Map sensor and the hose that is connect on the back if the sensor is disconnected then connect it (with the car off) then start the car then check if it stills kicks if this doesn't work well, then check the supports see if they are still good or are they crack or torn if they are that your problem. check all the supports
opcorn:
Old 08-14-2007, 08:21 PM
Thanks, will check that out.
