Go Back   Automotive Forums Car Chat > Hyundai > Elantra | Avante
Old 08-10-2007, 09:00 AM
Perrybucsdad Perrybucsdad is offline
Question 2002 Rotor removal
I am trying to replace the pads and rotors on the front of my 2002 Elantra GT. I have changed brakes before, and normall after I remove the set screws, I just have to hit it once or twice to loosen the rotor, but on my Elantra, the darn thing won't budge. Any suggestions, or is there something else I need to remove first, or another method to remove them.
Also, will I have the same issue on the rear rotors?
Old 08-10-2007, 09:58 AM
Jalmir's Avatar
Jalmir Jalmir is offline
Re: 2002 Rotor removal
the rotor might be stuck in rust, mine was and a 5lbs sledge hammer didn't do anything, I had to slice parts of the rotor with an angle grinder and hit the rotor a few times, it gave up and I could change it ...
So you need a sledge hammer, an angle grinder and patience!
Cut the base of the rotor (not the exterior parts that the pads press to brake, the center part of it) be carefull not to cut too deep or to cut the wheel studs or to cut the hub.
When you have done a nice and not too deep line in that center part of the rotor
take the sledge hammer and give it a few hit on the exterior part of the rotor (the section use to brake) the rotor will give up and split in 2.
That's how I took one of mine that was stuck there.
Old 08-11-2007, 10:00 PM
k2kiceman k2kiceman is offline
Hyundai brake rotors are almost a machine fit and many require splitting the rotors to remove them, especially in the rust belt states. When I reinstall them, i coat the back of the rotors with an anti-seize compound to help the next time in removal.
