Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 08-10-2007, 08:39 AM
trs's Avatar
trs trs is offline
poor pick up
i have a 200 sunfire, acn someone tell me why my can hesates when i go, its like it has to build up preasure or something. i can put the gas peddle to the floor ands it take 2-3 seconds to go. can someone please help me out. need more info just ask.
thanks
tommy
Old 08-10-2007, 10:21 AM
muff34 muff34 is offline
Re: poor pick up
It could be any number of things .
1 What size of engine ,how many clicks on it .
2 -Any mods been done to engine..
3 -Are there any idiot lights on?
4 -When was last tune up ? Have plug wires been changed .
5 -how about the fuel and air filter ,new or old .
6 -how does the engine perform otherwise good or does it sputter?
Life Is A Highway ,Enjoy The Ride
Old 08-10-2007, 12:14 PM
trs's Avatar
trs trs is offline
Re: poor pick up
1 What size of engine ,how many clicks on it . it is a 2.2L with 1403000 km
2 -Any mods been done to engine.. NO
3 -Are there any idiot lights on? NO
4 -When was last tune up ? Have plug wires been changed . last year
5 -how about the fuel and air filter ,new or old . fule last year, and have a k&n filter i clean every 6 months
6 -how does the engine perform otherwise good or does it sputter? it runs fine, no problems with it.
i also forgot to say it happens in d, when i put it into 3rd, it picks up fine. and it is automatic.
thanks
tommy
Old 08-10-2007, 04:32 PM
ChemMan ChemMan is offline
Re: poor pick up
Does the engine rev when you step on the gas, or does it bog down?
2010 Mazda CX-7 2.5L 12000 miles
2003 Chevy S10 Extreme 4.3L 57000 miles
1995 Buick Lesabre Custom 86000 miles RIP
2002 Pontiac Sunfire SE 130000 miles RIP
1997 Pontiac Bonneville SE 91106 miles Totaled by attempt to steal the car!!
R.I.P. 1978 Ford Fairmont 83000 miles
Old 08-10-2007, 08:59 PM
trs's Avatar
trs trs is offline
Re: poor pick up
it does nothing, does not rev or anything, like at a red light, go to hit the gas and it waits than goes , like i said before , like it is building pressure or something. how do i check for vacume leaks?
tommy
Old 08-11-2007, 03:55 PM
Re: poor pick up
In that case I would definitely check for vacuum leaks and have the car scanned for trouble codes. There are little plastic/rubber lines running off the throttle body to your fuel pressure regulator, power brake booster, and evap system. All these lines need to be inspected closely for breaks, cracks, and to make sure they fit snuggly on their connections. Sounds like you need to go buy a Haynes or Chilton manual for your car at this point. You can get them at an auto parts store for $20 and will help you a lot.
Old 08-11-2007, 09:51 PM
Re: poor pick up
I would maybe change the fuel filter and get fuel pressure checked. I had the fuel pump go out on mine 100,000 k,s. Some people use carb cleaner and spray it around throttle body etc with the car running ,it it starts to rev you`ve found a leak. an unlit propane torch has also been used .
