Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-09-2007, 07:59 PM
tex311 tex311 is offline
What Trans.
I have a 1984 capric classic with a 5.0l. How do I find out what size trans I have....Mines Broken
Old 08-09-2007, 08:13 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: What Trans.
Your car will have either a TH700R4 or a TH2004R. Most all '84s I've seen have TH700R4s bolted to the 5.0. The 700R4 has a rectangular pan while the 2004R has a pan that's rectangular in the front, trapezoidal at the back, and has two sumps (a large main sump and a smaller sump behind it at the trapezoidal portion of the pan).
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-09-2007, 08:42 PM
Re: What Trans.
Ok...What other 700r4 models will work?? I've seen this trans advertised for sale that came from a suburban will it still work even if it means changing the mount
Old 08-09-2007, 09:06 PM
silicon212's Avatar
Confoundingly Lucid
Re: What Trans.
It should work if it's not for a 4WD. Just make sure it works before you get it. Provided your car has a 700R4 in it to begin with.
When you put it in, make sure you properly adjust the TV cable or it won't last.
Old 08-10-2007, 12:42 PM
deesandvees's Avatar
deesandvees deesandvees is offline
Re: What Trans.
I'm swapping my 200 out for a 700...Is there any crossmember modifications needed to do this swap?
Old 08-10-2007, 01:30 PM
silicon212's Avatar
Confoundingly Lucid
Re: What Trans.
If you can get a 700R4 with dual mounts - one on the tailshaft housing, then no. If, however, you get a standard one - then yes, the crossmember will need replaced with the 700R4 one. Also, you will need a different driveshaft as the two transmission lengths are different - the 700R4 is about an inch and a half longer - so you will need the proper driveshaft as well.
Other than that, the swap is straightforward.
