Old 11-13-2002, 03:32 PM
iceiso iceiso is offline
Send a message via AIM to iceiso
what are blocks and heads?
haha, as you can see, i'm not very familiar with the inside parts of the engine. i'm sure someone can help me cuz i see these two words thrown around alot!!!
lots of time, i hear ppl say "h22a head with so and so block" or "keep the block and just switch the head". something along those lines; what are blocks and heads? also, if they fit inside a big category, such as, well, i'm not sure, engine parts, something LIKE that, could you please inform me of the other parts under that category. i want a swap, but i want to know every single specific before i even start looking for an engine.
thanks alot for the help!!!
Old 11-14-2002, 12:40 AM
Fishcat37's Avatar
Fishcat37 Fishcat37 is offline
Send a message via AIM to Fishcat37
The block (also called the shortblock) is the bottom end of your motor. The engine code is stamped on this. It houses the crank, pistons, connecting rods, cylinder walls, etc. It is pretty much everything bellow the head gasket...all the way down to the oil pan. The head is what is mated to the block. It contains the camshafts, valves, combustion chamber, valve springs, retainers, cam gears. The distributor mounts to it, along with the Intake manifold and the exhaust manifold. The complete motor (minus the transmission) is called the longblock (both the block and the head, intake manifold, exhaust manifold distributor, etc.) hope this ramble helped you a little
FLINT BLACK 1990 CRX SI
Appearance Mods:
-JDM EF8 CR-X SiR Spoiler
-94/95 Integra GS-R rims
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-Skunk2 Intake Manifold
-DC Sports 4-2-1 Header
-MSD SCI-L ignition
-EXEDY Racing Clutch
Interior Mod
-'95 Integra GS-R Gauge Cluster
Former Motors - RIP:
-JDM B16A #1- Blew up due to over-revving
-JDM B16A #2 - Hydrolocked
Former Cars
'89 CRX Si - "The Bumblebee"
'94 Integra GS-R
'96 Camaro
Old 11-14-2002, 01:55 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
sorry fishcat,the combustion chambers are in the block,you know where the pistons and rods live.But I'm sure this is just an oversite.
