Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 08-09-2007, 06:59 PM
Lbrizi Lbrizi is offline
Cool Need Help break light swicth
Trying to install a break controler an a 96 tahoe and I need to know where the break lite switch is or what wire I tap into ??
Any help will be great
Thank you Larry B.
Old 08-09-2007, 08:16 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Need Help break light swicth
Thank you Larry B.
The brake light switch is positioned in a bracket and mounted immediately behind (that is, as viewed from the front of the car - it's between the driver and the brake arm) the brake pedal arm. It contacts it directly. There may be more than one circuit attaching it, however - so the best thing is to go get a manual on the vehicle and look at the wiring diagrams.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-10-2007, 10:18 AM
777stickman 777stickman is offline
From my '98 C/K manual the wire you need to find at the brake switch is the white one. Your '96, hopefully, is the same.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
