Old 08-09-2007, 06:14 PM
no-logic no-logic is offline
Can't get the key out
My '97 Blazer has been doing this for some time and it is getting worse. The tumblers will not turn all the way to the lock position so I can't get the key out. I removed the plug under the column and use a small screwdriver to push the override release to get the key out but it is getting to be a PIA. Anyone had this problem and actually fixed it?
Old 08-10-2007, 08:00 AM
laxman21's Avatar
laxman21 laxman21 is offline
Re: Can't get the key out
Sounds like you need a new switch before the key gets stuck in it. Happened to me while it was running.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 09-08-2007, 02:49 PM
If you are referring to the ignition switch I replaced that for a no start condition and it didn't have any affect on the key problem.
Old 09-08-2007, 05:06 PM
silverblazer silverblazer is offline
Lightbulb Re: Can't get the key out
I've had that problem once in a while, most times I cant turn the key on. Try turning the steering wheel back and forth.
1995 Chevrolet Blazer LT
4x4 Red and Silver
CHEVYS RULE
Old 09-09-2007, 09:11 AM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
I'm going to refer you to a link where I posted the same problem.
If you have a floor console shift, lift the boot cover up, and make sure the pin on the passenger side of the shift mechanism is working properly.
If not, clean and light oil it. It's a 2 piece white plastic mechanism, you'll see it move as you shift through the positions. The disc-pin that slides horizontally may be the problem.
If that doesn't solve the problem, you'll have to replace the solenoid on the steering column (I took mine out). It's about a 15 minute job. Remove the bottom and top wheel shrouds, then remove the solenoid pack from behind the key cylinder (black and green wires). You'll need an M4 socket to get the torq bolt off (or a needle nose pliers)
http://www.automotiveforums.com/vbul...d.php?t=744170
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
Old 10-19-2007, 03:08 PM
Richard Riefler Richard Riefler is offline
I have the problem with my wife"s "97".I tilt the wheel up and down
once or twice and it works fine
Old 01-02-2008, 10:24 AM
yukonwinter yukonwinter is offline
1992 jimmy slt...same problem. Stuck in the run position. Had to pull the wire off the coil and disconnect the battery to shut it down. Gonna work on it today. Should be fun.
