Go Back   Automotive Forums Car Chat > Mercury > Villager
Old 08-09-2007, 05:23 PM
wood woman wood woman is offline
96 villager overheating
Hello!
My 96 villager doesn't have working air or heat. The mechanic said he'd have to pull out the dashboard to fix it. That's really not the problem, though. It's 100 degrees here this week and it's been overheating. When you turn on the heat, however, it draws heat off the engine so you can at least get where you're going without stalling. I've checked the coolant and it's full. Does anyone have any idea of what it might be? We'd really like to drive it till it drops and have had pretty good luck with it, other than doing stuff like replacing parts that have just worn slam out. BTW, it has 144,352 miles on it. Thanks.
Old 08-10-2007, 10:29 PM
QuestOverload QuestOverload is offline
Re: 96 villager overheating
Does the fan kick on high? It's obvious when it does. How does it act when it's overheating (when does it do it, does it creep up or shoot up to hot, how hot has it gotten)? Does it always do it or is it random? One of ours does it at random, and I've personally replaced everything but the waterpump, which the lying previous owner said was done 6 months ago, and I've concluded that it's eaten up and not pumping right, but with a heat index of 113ºF, I'm not even touching the stupid thing right now! LOL
HTH
Questoverload
1996 Villager (newest, 80k miles, CLEAN!!)
1995 Villager 147k (new driver, bad lifters, 24.5mpg)
1993 Mercury Villager 156k (fair game for parts)
1993 Mercury Pillager 178k (Pillaged 4 parts)
1995 Nissan Quest 194k (driver)
1995 Mercury Villager (sold 181k)
1996 Mercury Villager (sold 134k)
1995 Mercury Villager (sold @ 184k)
1993 Nissan Quest (sold @ 137k)
1998 Mercury Villager (sold @ 90k)
Old 08-11-2007, 03:19 AM
Bob Mayo Bob Mayo is offline
The first thing I would do is replace the thermostat. The part costs less than $20. and anyone who is handy with tools can replace it. Of course a shop is going to charge you over $100. to do it. If the thermostat fails to open the engine coolant cannot circulate and the engine will overheat. If that does not fix the problem you have not spent too much.
As for the AC/Heat problem.....does the blower motor turn on and blow air into the interior? If not then you could have a bad blower motor or fuse or relay. The dashboard does not have to be pulled out to replace the blower motor, only a couple panels under the passenger side dash. The part is about $75. and the labor should be no more than one hour.
Old 08-14-2007, 05:26 AM
IH8SPM's Avatar
IH8SPM IH8SPM is offline
The system could also be air locked and needs to be bleed properly to remove excess air from the cooling system. In addition the may have a bad AC/heater control which does not turn on the ac. Check everything that is free and DYI then move on to be parts and mechanics. It works if you run the heater that is a sign of a small problem and not a big one.
Old 08-14-2007, 10:25 PM
Good suggestions, I didn't even see the part about the blower fan not working. It could be the controller as was suggested, but I've never seen one make the front air quit, just the back. I'd bet money on the resistor pack on the heater box being toast and keeping the fan from getting juice. It's a Ford design straight out of 1962 and they've always been trouble, I replaced one in my 66 mustang, 91 escort and 93 villager in the same week. Came to find out the Escort one was actually good so I used it on the van, plugged right in. It's an easy DIY too, just pull the glovebox, which is a 5 minute job on a 95 and a 15 minute one on a 96, but it's still easy.
The resistor pack is ~$10-20 from PepBoys/AutoZone.ect
Old 08-15-2007, 03:27 AM
Hey QuestOverload, Ever change a front wheel bearing on a villager? See my post dated August 10. Thanks. Bob
Old 08-19-2007, 08:40 PM
The motor that runs the fan had burnt out and had to be replaced. I guess at 144K miles it isn't surprising. This is the first time we've replaced it. It's been a pretty good vehicle and we've had it for 11 years. Thanks for all your sugguestions!
