Go Back   Automotive Forums Car Chat > Chevrolet > El Camino
Old 08-09-2007, 12:20 PM
BBBDAL BBBDAL is offline
Tail Light problem
Hope someone can point me in the right direction. The drivers side tail lights work fime. The passenger side barke and blinker do not light up at all. If I turn the light on the tail light does light up but no brake or blinker. I have replaced the bulb and disassembled and the wiring looks ok to my eyes. Any ideas?
Old 08-09-2007, 08:10 PM
rhandwor rhandwor is offline
Re: Tail Light problem
Look for corrision around the bulb. Did you use a new dual element bulb. It will have two contacts on the base of the bulb. Otherwise use a 12volt test light and check for power.
Old 08-10-2007, 08:24 PM
mitademedio mitademedio is offline
yep check that you have the correct bulbs,I had the same problem with mine.
