Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 08-09-2007, 11:47 AM
davedirt davedirt is offline
Question Airbag code 22?
I have a 2001 Lincoln Town Car Exec, the air bag light flashes twice, stops, and then flashes twice again. I am guesing that this means code 22, which I found on this forum to read "Safing sensor output circuit shorted to battery voltage" Does anyone know what I need to do to fix this?
Old 08-09-2007, 06:46 PM
reekor reekor is offline
Re: Airbag code 22?
Sounds like a shorted clockspring.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 11-27-2007, 05:50 PM
Blaze_316_316 Blaze_316_316 is offline
Send a message via MSN to Blaze_316_316 Send a message via Yahoo to Blaze_316_316
Re: Airbag code 22?
HAS ANYONE FIXED THIS PROBLEM I REPLACED CLOCK SPRING AND IT GOT RID OF 1 CODE! PLZ HELP
200 Hp Quad 4 H.O. W41 Cams + Prom,
Rebuilt Motor
90 Cutlass Supreme International Quad 4 HO 5 SPD
91 Grand AM SE Quad 4 HO 5 SPD
92 Grand AM SE Quad 4 LO 3 Spd Auto
Old 12-03-2007, 08:03 AM
dugan50's Avatar
dugan50 dugan50 is offline
Authorized Vendor
Re: Airbag code 22?
Both of these answers are wrong for this vehicle. The probelm is in the side airbg circuit. Every vehicle has it's own diagnostic DTC chart and although some codes are similar, this is something that needs to be EXACT, or you will cause yourself a lot of trouble.
The correct flow chart is available on our website and it's worth the cost to get the right information about your own car. Everything can be printed so you only have to log on once
I hope this was helpful to you. My information comes from years of experience in these businesses.
http://www.airbagsolutions.com http://www.stolenandrecovered.com
Airbag Service, Airbag Replacement, Airbag Diagnostics
Thank You,
Douglas Gan
