Go Back   Automotive Forums Car Chat > Hyundai > Sonata
Old 08-08-2007, 09:38 PM
kbherbie kbherbie is offline
Hyundai 2000 code P0171
I am looking at buying a this car for my daughter and the check engine light came on while test driving I went and had a diagnostic test done and it showed a code P0171 System too lean . What would this be and how much could I expect to pay to fix the problem I can get the car for $2000 it has 103k is this a good deal with this problem? Karla
Old 08-09-2007, 10:59 AM
Jalmir's Avatar
Jalmir Jalmir is offline
Re: Hyundai 2000 code P0171
the complete description for the code is :
System too lean, bank 1 Intake/exhaust leak, AIR system, MAF/VAF sensor, fuel pressure/pump, injector(s), HO2S
The first thing to check is for a vaccum leak or an intake gasket leak, also check the MAF and first oxygen sensor.
Old 08-10-2007, 07:12 AM
Red face Re: Hyundai 2000 code P0171
Thanks for you reply. Do you have any idea how much this would cost if you take it in. And is the a serious problem? Thanks for your input. Kb
Old 08-10-2007, 10:05 AM
Jalmir's Avatar
Sorry I really don't how much it would cost, I mostly do all that myself and when I find the defective part I go buy it and change it myself ...
And yes, it's a serious problem, a car that run lean will eventually die, lean means there is not enough fuel getting in the engine (hence a possible vacuum leak : more air gets in the engine) fuel also act as a lubrican and help cooling the engine down a little, so if you keep on running lean the engine will be damaged and will eventually need to be change.
