Old 08-08-2007, 03:19 PM
SkyLyons SkyLyons is offline
odd noise when i turn corners
almost every time i turn a corner my wheels make wierd sounds. it sounds like a old creaking door or something odd like that.
Old 08-08-2007, 04:23 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Re: odd noise when i turn corners
if it's a clicking noise then it may be your cv joints
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 08-08-2007, 06:19 PM
thefooshmeister thefooshmeister is offline
Send a message via AIM to thefooshmeister
it could be a ghost!
98 Jetta GLX VR6-vroom vroom!!
91 CRX Si-R..busted..
Old 08-08-2007, 06:57 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
A creaking likely would not be the cv joints..wheel bearings would be likelier, or maybe just some worn out or loose bushings.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 08-08-2007, 07:18 PM
viper-blue's Avatar
viper-blue viper-blue is offline
yeah for sure, or even more likely the strut bearing
89 crx SI - spoiler, custom viper blue paint job, Z6 just completed, stock 14's with a 3 inch drop, sidemarkers, and the stereo
"my crx is like my woman: don't like anyone touching her, or driving her but me!"
Old 08-09-2007, 12:24 AM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
yeah... since when are struts moving parts that require bearings?... I think you mean bushing here? just a thought.
Don't forget to check your headlight fluid before you drive. :P sorry, had to.
Old 08-09-2007, 01:39 AM
viper-blue's Avatar
the strut bearing is what allows the strut to pivot when you turn the stearing wheel. It starts off making a squeeling noise when you turn the steering wheel and eventually starts to grind, or thump. The bushings are mounted above the bearing. :P
number 8 and 10 on the link is the bearing: http://www.hondaautomotiveparts.com/...SHOCK+ABSORBER
Old 08-09-2007, 04:21 PM
eh, we just call that whole assembly the strut tower mount... lol.. difference in terminology I guess, my apologies.
Old 08-09-2007, 04:25 PM
FrodoGT's Avatar
I find that the LCA bushings and upper arm bushings creak real bad sometimes..just give the whole thing a good check over, take the wheel off..make sure nothing is loose, go over them all with a wrench and then put some white lithium grease on all the bushings you can see, that should do it.
Current project:
Rio Red 91 hatch.
