Old 08-08-2007, 03:18 PM
PlayStation3 PlayStation3 is offline
x over question
ok i have a question. i plan on using my 2 12" to play below 150hz then get 2 midbass drivers and have then play from 150hz to like 400hz or so in a sealed box and then just have the speakers have a highpass set at like 63 hz or so. now i am planing on running 3 amps so i will use the x-overs on the amps. now will this sound good or . and for the subs they will probelly ported and probelly be tuned around 32 hz will also i want to try kickers cvx for subs.
Old 08-08-2007, 07:55 PM
bjboertje's Avatar
bjboertje bjboertje is offline
Re: x over question
150 is pretty high for a sub to play. the midbass region is more like 80-200.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 08-08-2007, 08:30 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: x over question
tune the sub box to more like 28 Hz, then crossover the subs at no more than 75 Hz
Old 08-08-2007, 11:15 PM
Re: x over question
ok cool. do any of you guys know any good midbass drivers?
Old 08-09-2007, 08:13 PM
Audio Guy
Re: x over question
do a 7" - 8" ..... you will have to look around
Old 08-09-2007, 08:21 PM
Re: x over question
i notice some call them subwoofers and some call them midbass drivers is there a diff?
Old 08-13-2007, 01:30 AM
Re: x over question
ok i got a question how can i make the midbass drivers only see frequency from 75hz to 200hz only. oh i am looking at either using Eu700 or mach5 audio MLI-65. and here is the amp that i am going to use. http://www.eclipse-web.com/amp/xa4000.html
Old 08-13-2007, 08:42 PM
Audio Guy
Re: x over question
a sub is designed to play down to at least 30 Hz but limited in the top range, a midbass driver can play up 500Hz or more. The way you make the midbass driver see only the midbass freqs is to use a xover. You either need one that has 4 way capabilty or you will need a 2-way and a 3-way.
Old 08-13-2007, 11:25 PM
Re: x over question
ok, so i should look at the MLI-65 more then the eu700 since that is a 6.5 subwoofer.
Old 08-15-2007, 06:13 PM
bjboertje's Avatar
Re: x over question
that mach 5 has a very nice price tag.
and yes, if you want to use it for midbass, then you would want to get a driver optimized for midbass.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
