Old 08-08-2007, 02:30 PM
Orchid Orchid is offline
Installing a car starter in a 97' Dodge Caravan
I think I need a new car starter in my car. When I turn the key all I hear is a click and the battery is working fine. I need to know how to install a car starter in a 97' Dodge Caravan? If anyone has any ideas or if anyone knows what else it might be please let me know?
Old 08-08-2007, 07:32 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Installing a car starter in a 97' Dodge Caravan
If you haven't already, jump start the van using jumper cables and another car. If it starts, it's a good sign the battery is weak. Just because lights come on when you turn the key doesn't mean the battery is fully charged.
If the battery is good, turn the key and tap the starter with a hammer. If it starts, you'll either need to replace the solenoid contacts in the starter or replace the starter.
Using a volt meter check for 12vdc at the starter connection where the smaller diameter wire connects. If it's there when you turn the key to start, you likely have a bad starter.
Here's how you troubleshoot and change a starter:http://www.autozone.com/az/cds/en_us...rInfoPages.htm
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 08-08-2007, 08:57 PM
vipergg vipergg is offline
Check the battery posts and cables and make sure there is no corrosion them , these can get an almost invisible high resistance film on them , get a good post brush and clean the inside of the battery cables and then the battery posts too until they are shiney.
Old 08-09-2007, 11:10 PM
Thank you to everyone who posted a reply. The battery is good, but it is definitely the starter.
