Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 08-08-2007, 01:08 PM
Yanqui Yanqui is offline
Exclamation squeaking noise when turning
Hello,
I have a 98 lincoln towncar signature series and when i turn all the way either to the left or right when am making a u-turn you can hear like a squeaking noise that is loud, anybody have an idea?
Old 08-08-2007, 04:45 PM
Towncar's Avatar
Towncar Towncar is offline
Re: squeaking noise when turning
Check the condition of your Septintine Belt, and check your Power Steering Fluid level.
Your suspension can also make squeaks and creaks but that's usually in correlation to body movement...
I'm not reading body movement into your post.
BTW.. you shouldn't turn ALL THE WAY to the point where you're stressing the Power Steering system.
-Steven
1996 Town Car, Cartier
Old 09-04-2007, 08:57 AM
My Septintine Belt is almost new i changed it less than a year ago and the power steering is on level, it only does it when you steer all the way and you put friction on the front suspension. Maybe i need to grease any front end component? any idea is a really loud noise like two metals rubbing with eachother
Old 09-04-2007, 05:31 PM
Towncar's Avatar
OK, if not related to steering I'm going to call it a creak.
A loud creak like that, in correlation with body movement could be coming from A Arm Bushings, Sway Bar ends or really bad Ball Joints.
Get under there and have a look.
-Steven
Old 09-04-2007, 07:48 PM
[email protected] moez1010@yahoo.com is offline
Sometimes if the power stering fluid gets low the filled air might be in the system.
Remove the cap on your fluid resevoir the turn the wheel all the way left then right a couple times'
Once the wheel comes to the end as far as it turns each way.
DO NOT HOLD IT THERE.
This will push air out of the system. You might see some bubbles in the fluid from the air that was pushed out.
Old 09-06-2007, 08:22 AM
k thank you guys i will get under there this weekeng and check it out.
Old 09-06-2007, 07:56 PM
tdc1948 tdc1948 is offline
Similar, perhaps. Today I had to turn very tight to get in a parking place. Ugly grrroooonk metal-against-metal sound. On the flat, going very very slow, no strains other than the super-tight turn. 2000 TC with 31000 miles, well maintained. Ay ay ay.
Old 09-06-2007, 09:28 PM
Bearfoot Bearfoot is offline
"Ugly grrroooonk metal-against-metal sound"
That's the sound made when the right front fender of your car scrapes the left rear fender of the parked car!
Stan
'98 Lincoln Towncar - white 100k
'08 Mercury Grand Marquis - maroon 30k
'98 Dodge 3/4 ton, Cummins Diesel, 4 x 4, 4 door, extended cab, long bed. 140k
