Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 08-08-2007, 12:46 PM
DrJohnW DrJohnW is offline
5.7L rough idle when cold
I have a 1999 Chevy Suburban, 1500, 2WD, 5.7L. It has a very rough idle when cold (1000 - 200 RPM but does not stall). The condition improves, and is unnoticiable when at operating tempertature. The throttle position sensor was changed - no improvement. It has new plugs, wires, cap, etc.
Old 08-09-2007, 08:26 AM
taillight taillight is offline
Re: 5.7L rough idle when cold
Try cleaning the throttle body, IAC(idle air control), and injectors.
Old 08-09-2007, 02:20 PM
Thanks. How do I locate the IAC? I am not familiar with that device.
DrJohnW
Old 08-10-2007, 09:07 AM
It is in the throttle body. Unscrew it and clean it with carb. cleaner.
Old 08-10-2007, 10:58 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Injector poppets are sticking closed causing your concern.
They cannot be cleaned with conventional injection cleaners, only by injecting high pressure nitrogen or by replacing the injection unit with an updated one.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 08-11-2007, 09:13 AM
I have had good luck cleaning GM injectors with a Sun Fuel Injector Cleaning Machine. I think I would try that first.
Old 10-05-2007, 01:16 PM
Kawazar Kawazar is offline
DrJohn have you had any luck? I have the same problem but I haven't addressed it yet.
Old 10-11-2007, 08:44 AM
Captain Ron Captain Ron is offline
Check the other post related to this issue. Sounds like an intake manifold crack or bad gasket. Very common, known issue.
