Old 11-13-2002, 08:46 AM
Santas90Si Santas90Si is offline
Registered User
Send a message via ICQ to Santas90Si Send a message via AIM to Santas90Si Send a message via Yahoo to Santas90Si
Damn squeaking noise.
when I first start my car one of the pulleys squeaks like hell then once it gets warm it does fine. I think it might be the A/C compresser. I have thought of taking the belt off but that would disable my defroster (so I have been told) Does anyone know for sure if it will?
Old 11-13-2002, 10:34 AM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
Noise
That noise is a belt and it could be either the alternator or the A/C belt. See if either or are loose a bit and tighten them up. Go ahead and rip the A/C if it dosen't work, and no it won't affect your defroster, your heater does the defrosting.
Old 11-13-2002, 10:00 PM
Registered User
Arrow
Te A/C works but it looks like its got leaves stuck behind the pulley...those might make it squeak. The altenator is new so I dont think thats it I squirted some open gear lube in the altenator behind the pully, where the shaft is and that help till it got cold again...
Old 11-13-2002, 10:47 PM
kris's Avatar
kris kris is offline
Off playing with fire.
My Wifes Crustang squeaked for awhile. I used some stuff called belt dressing on the belts. So far so good, and it's in the 20's here.
Old 11-14-2002, 12:23 AM
BullShifter's Avatar
i had the same deal with mine. it made a cricket chirping type noise until warming up. tried spaying something on the belt & still the noise was there. Narrowed down to the alternator which wasn't hard because it has no P/S or A/C. the alternator is very simple to change well not simple but pretty easy
squeaking noise PUpilot007 Wrangler 3 02-13-2014 01:26 PM
squeaking noise mandygrl Neon | Plymouth Neon 2 10-13-2003 08:44 PM
Squeaking Noise/ help? Bethie Mustang Talk 5 07-28-2003 07:07 AM
Horrible Squeaking Noise mightytexn '88 - '91 Civic | CRX | Wagon | Shuttlee 7 11-12-2002 06:11 PM
Squeaking noise when clutch is realeased??? 96LSIntegraRocket Integra 2 05-11-2002 05:27 AM
