Old 08-08-2007, 12:43 AM
idreamofdatsun idreamofdatsun is offline
engine rpm and tire rpm question
Why doesnt engine rpm transalte into tire rpm ? Your engine might be cruising away at 5000rpm but your only doing 30mph where do all the engine revolutions go ? Is something slipping (assuming the tires arent) ? Do you understand what i mean ?
Old 08-08-2007, 01:26 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: engine rpm and tire rpm question
Wow.
OK.
In order to translate crank shaft rotation into wheel rotation drive is first transmitted through a variety of geared mechanisms, usualy consisting of a gear box and differential.
These change both rotational speed and rotational torque to both make better use of the engines power out put, and to direct in the right direction.
Or,
You could just goto www.howstuffworks.com and look up "gears".
Or better yet buy a lego technics set with some gears in it, and have a play.
Old 08-08-2007, 01:51 AM
Originally Posted by Moppie
Wow.
OK.
Or,
oh wow geez i knew that i just didnt think of putting those two together but it makes alot more sense after reading the pages on howstuffworks.com
i think thats where ive learned most of what i know about cars actually
anyway thanks i see now
Old 08-08-2007, 02:26 AM
Moppie's Avatar
Master Connector
No worries
