Old 08-07-2007, 08:20 PM
gta333 gta333 is offline
a/c problems
We have a 98 chevy lumina. Last week we notice when drivng with the a/c on that every so often what looks like smoke would come thru the vent. Its been really humid here. Then today I noticed I high pitched noise. I Pulled over and turn car off. The noise was still there. Then when turning into neighborhood it stopped with 3 loud chimes like when you start the car. Is this the compressor going bad. Any help would be nice as We have a 4 day trip planned later in the week. thank gary
Old 08-08-2007, 08:26 AM
maxwedge maxwedge is offline
A990 racer
Re: a/c problems
Welcome to AF, regarding the mist in the ac vents, look for a clogged drain tube, r/s of cowl down low behind the engine. Noise ,has to be determied on site for obvious reasons.
Old 08-08-2007, 04:53 PM
Re: a/c problems
well the blower motor went out today. Hope that this is the only thing wrong. thanks for your replay. gary
Old 08-08-2007, 05:20 PM
Re: a/c problems
WELL JUST COME IN FROM LOOKING AT THE CAR. IT SEEMS THAT THE PASSENGER SIDE FOR IS SOAKED. lOOKS LIKE A HEATER CORE PROBLEM. BUT WHY WOULD MY BLOWER FAN QUIT? LOOKS LIKE THERE IS MORE PROBLEMS THAN i THOUGHT. THE A/C HAS BEEN WORKING FINE UBTIL THE BLOWER MOTOR STOPPED TODAY. I DID NOTICE THAT THE AIR COMING FROM THE VENT IS VERY HOT. DOES THIS MAKE SENSE TO ANYBODY. i HOPE THAT THERE IS NOT ANYTHING WRONG WITH THE COMPRESSOR. ANY ADVICE OUT THERE TONIGHT. THANKS GARY
Old 08-08-2007, 07:23 PM
A990 racer
Re: a/c problems
Check if you have lost coolant, is the wetness water or antifreeze, again the drain can cause this, if water.
Old 08-09-2007, 06:24 AM
Re: a/c problems
Yes the drain was plugged. It draons fine now. But I still have the problem with the blower motor. Thinking that the water might have something to do with this. could it have blown a fuse if it got wet and went to ground. If so where would the fuse be at for the fan motor. thanks for the quick replies. This forum I see can be really helpfull. thanks gary
Old 08-09-2007, 07:42 PM
A990 racer
Re: a/c problems
Blower fuse should be in the r/s dash fuse panel I believe, see if there is 12v to the connector also.
