Go Back   Automotive Forums Car Chat > Hyundai > Elantra | Avante
Old 08-07-2007, 06:55 PM
NOHO NOHO is offline
REPLACING HEADLIGHT on 2004 elantra
I'm not mechanical at all,so i don't know if i can replace my head light myself or not. Can someone please advise. thanks
Old 08-08-2007, 09:24 AM
Jalmir's Avatar
Jalmir Jalmir is offline
Re: REPLACING HEADLIGHT on 2004 elantra
All you have to remove is the 3 10mm bolts, plus 2 electrical connections (turn signal and high/low) ... as simple as that. Good luck!
Old 08-10-2007, 09:31 AM
Perrybucsdad Perrybucsdad is offline
Are you talking about replacing the entire head lamp assembly, or just the bulbs? Bulbs are very easy, but a bit hard to get your hand down in the area. Just turn the plastic cap that is on the back, pop the spring clip, and then remove. When you put the new bulb in, make sure you do not tuch the glass with your skin. The oil from your hand will cause it to burn out very fast. Replace the bulb in the lamp assembly, put the spring back in and hook the wire back up and replace the screw cap and you are all set.
