Old 08-07-2007, 06:59 PM
skycap skycap is offline
94 accord 4 cyl high idle
my sons 94 accord 4 cly has a high idle when warm/hot about 1800 rpm, can any one tell where to look? also check engine light is not on thanks a bunch!
Old 08-08-2007, 08:56 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: 94 accord 4 cyl high idle
Make sure the coolant is full, then check for vacuum leaks. Sucking air where they shouldn't will force a high idle, without a CEL in OBD-I cars. Make sure the throttle plate linkage is landing on the idle stop screw when idling...a dirty throttle plate can sometimes hang up and not fully close due to deposits.
Check for vacuum hoses that may have split or fallen off, spray around all of them and the intake manifold with some water or WD-40 and the idle will react if it sucks it into the leak, and points you to the right area...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
