Old 11-13-2002, 01:08 AM
SCT_Type-S SCT_Type-S is offline
Send a message via AIM to SCT_Type-S
Why is it smoking?
I am thinking about buying a 1995 Mitsubishi Eclipse GSX but it has a problem and i don't know what the signs of it mean. any info would be greatly valued.
The dealership stated that when the car is first turned on it sends out a puff of smoke from the exhaust, and, while driving on the highway they said it also let out puffs of smoke when shifting gears but cruising was ok. I would just like to know what the problem is and maybe how to fix it. Thanks a lot.
Sam
Old 11-13-2002, 08:23 AM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
wat color is da smoke, black, gray white
black smoke means u probably have a oil leak or possibably your pistons rings are gone,
i think also that gray or white smoke can mean that u are running rich or lean
not 2 sure
Old 10-21-2005, 02:24 PM
AbsoluteGTR's Avatar
AbsoluteGTR AbsoluteGTR is offline
Send a message via AIM to AbsoluteGTR Send a message via MSN to AbsoluteGTR
Re: Why is it smoking?
Hey sorry for bringing back this old post, but its better than creating a new one...
Anyways my car 1997 rs eclipse has the same problems:
when the car is first turned on it sends out a puff of black smoke from the exhaust, and, while driving on the highway it also lets out puffs of black smoke when shifting gears but cruising is ok. I would just like to know what the problem is and maybe how to fix it. Thanks a lot.
Old 10-21-2005, 05:16 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
Well if you were turbo i could tell you, thats all signs of a turbo going bad, but since your not turbo sorry man
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 10-21-2005, 08:02 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
ok GENERALLY
white smoke = coolant
black or gray = unburn fuel
blue = oil
However a bad turbo can also smoke white depending on where it's burning oil.
Even if you're a non-turbo, black smoke means running rich. Your ECU is sending out too much fuel or not enough air is getting through. Try a new air filter first.
now - 2000 civic
soon - 2002 is300
Old 10-21-2005, 10:01 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
dissconnect your negitive terminal from your battery for 10 seconds. If that dosn't fix it, you migh have an injector sticking open, or bad o2.
DSM geek
Old 10-21-2005, 10:04 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
explain this battery thing to me... i just wnana kno how it works
Old 10-21-2005, 10:38 PM
it resets the ecu
it erases the old code and if it comes back on that's your problem
now - 2000 civic
soon - 2002 is300
Old 10-21-2005, 10:44 PM
well, yeah it resets the ecu to its factory air/fuel & timing maps
DSM geek
Old 10-21-2005, 11:24 PM
Yea at first I thought (and still think that is running rich). The first thing I will do is buy a K&N airfilter. My other one is beat up. So which O2 sensor would be bad? (The one on the intake manifiold, right?)
Also what is this thing about a fuel injector open?
Thanks
Old 10-22-2005, 08:53 PM
Thanks
Old 10-22-2005, 11:07 PM
TreeFrog's Avatar
TreeFrog TreeFrog is offline
Send a message via AIM to TreeFrog
yeah it would be your front o2 sensor. I bet thats what it is. What kinda gas mileage are you getting? my o2 sensor went bad, and i knew cause my mile per gallon went down to like 12
Something new is coming...
Old 10-22-2005, 11:12 PM
clipsekid99's Avatar
clipsekid99 clipsekid99 is offline
Send a message via AIM to clipsekid99 Send a message via MSN to clipsekid99
Could the O2 sensor go bad and not throw a CEL? Cause I'm filling up every week just goin to school (30 min away) and work (2 min away).
2006 Wicked White Evo IX GSR
323 awhp / 311 tq. (Dynojet)
http://www.projectevoix.com
http://www.4WStuning.com
99 RS < 98 GSX < 06 EVO
Old 10-23-2005, 12:39 AM
I mean my gas is shitty, but I drive ALOT and drive kinda crazy too! I dunno I have to get a new airfilter anyways, (the old one is extremely beat up). But I doubt that, that is the problem, beacuse the 02 sensor would compensate for the lack of air by adding less fuel, right?
But IF my O2 sensor is bad, how would I change it and also how much $$$ ??
Thanks!
Old 10-23-2005, 11:30 AM
o2 sensors are kinda expensive. 30-50 for a bosh. all you need is a 22mm long open end wrench and its a cake walk. The o2 does through a cel when it dosnn't ossilate like it should, but their are other ways a o2 sensor can become bad.
Dissconnect the battery... let it warm up for 3-5 mins so the o2 can reach 600 degrees. then take it for a spin and see if it still has black smoke. Then try replacing the front o2.
Still blowing black smoke you have a air/fuel delivery problem and unless you have the knolege to diag the issue i suggest spending the $75 to have your local Mitsubishi Service Department to diag it for you. Then you can fix it yourself.
DSM geek
96 GMC Jimmy black smoke, backfires, Timing? corhey88 Jimmy 38 01-31-2010 03:29 PM
91 Blazer Blows Smoke 91s10blazen S-10 6 11-25-2009 07:56 PM
Exhaust smoke lmattiso Rodeo | Passport | MU 2 11-23-2009 06:55 PM
88 IROC smokes after idling a few minutes.. IROCmenace F-Body Problem Diagnosis 6 10-13-2009 08:34 PM
smoking from the oil filler cap, dipstick and exhaust jimgbgt MGB 2 07-24-2009 04:26 AM
