Old 11-13-2002, 01:02 AM
SCT_Type-S SCT_Type-S is offline
Send a message via AIM to SCT_Type-S
Why is it smoking?!
I am thinking about buying a 1995 Mitsubishi Eclipse GSX but it has a problem and i don't know what the signs of it mean. any info would be greatly valued.
The dealership stated that when the car is first turned on it sends out a puff of smoke from the exhaust, and, while driving on the highway they said it also let out puffs of smoke when shifting gears but cruising was ok. I would just like to know what the problem is and maybe how to fix it. Thanks a lot.
Sam
Old 11-13-2002, 01:15 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
what color smoke comes out ?
Old 11-13-2002, 01:21 AM
It doesn't specify that. I'm sorry.
What would it mean if it were:
Blue:
Black:
White:
or
Grey:?
Old 11-13-2002, 08:28 AM
Belldandy's Avatar
Belldandy Belldandy is offline
Blue smoke it's leaking oil
White Smoke it's leaking coolant
Black I believe was Carbon buildup or running rich.
Grey don't know perhaps leaking tranny fluid ??
2000 4dr Civic Ex 'Clover Green Pearl'
Anime Rocks
Kurumi and Naru Narusegawa are awesome!
Old 11-13-2002, 10:54 AM
Dblade Dblade is offline
thatd be phat to have blue smoke comming out of my car lol
Old 11-13-2002, 12:23 PM
RoBoDEATH RoBoDEATH is offline
Send a message via AIM to RoBoDEATH Send a message via Yahoo to RoBoDEATH
mine runs to rich and it's black smoke but only at high rpms, i guess i need a air/fuel gauge and a fuel pressure regulator
1998 Honda Civic EX--Si Wing--Jackson Racing Supercharger--Enkei RP07 18inch Rims--Yokohama PARADA 215/35ZR/18's--K&N Filter--Hurst ShortShifter--DC Sport Header--Greddy Cat-Back Exhaust--DC Strut Tie Bar--Eibach Springs with Ground Control Coil Overs--Ingalls Rear Camber Kit Arms--Skunk2 Front Camber Kits--Panasonic DF88 CD Player--Two 1Fared Caps--Sony Xplod 800W Amp--SPL Series II 1200W Amp--Solo Baric 15--!!!!!SOLD!!!!!!!
2001 Honda S2000 NFR--HKS Hi-Power Duel Exhaust--NRG Hood Dampers
Old 11-13-2002, 01:28 PM
moondawgy's Avatar
moondawgy moondawgy is offline
if your car is very very cold, it will blow white smoke as well. usually happens during the winter time when u dont warm up ur car before u drive.
Old 11-13-2002, 01:53 PM
shepworldwide's Avatar
shepworldwide shepworldwide is offline
piston rings could be bad.???
:twoguns:"shepworldwide":twoguns:
96 integra for sale or trade
huge northest meet may 31st. come check it out.
Old 11-14-2002, 04:41 PM
Cyprus106 Cyprus106 is offline
Send a message via AIM to Cyprus106
Yea, if it puffs smoke when it starts up, I'd say piston rings.
Hung by a halo or stabbed by horns, sad to say; they're both the same
Old 11-15-2002, 03:26 PM
maxspeedhonda's Avatar
maxspeedhonda maxspeedhonda is offline
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
Sounds just like my car. I run mine rich for the turbo so I know thats what it is. I have has fried piston rings before and when that happened it was black smoke all the time and LOTS of it.
Old 11-15-2002, 07:26 PM
york2600 york2600 is offline
Send a message via AIM to york2600
piston rings
How much are new pistons rings installed?
-Tim
94 Integra GSR Coupe
Mods: Professionally Built B20/VTEC: B18C1 head w/ pocket port, JE oversized pistons, Eagle Rods, block guard, ARP head studs, Skunk2 Intake Manifold, STR Throttle Body, AEM CAI, AEM Fuel Rail/Regulator, RC Engineering 280CC injectors, Denso Iridium Plugs, Magnacor Wires, DC Sports 4-2-1 SS Header, Greddy Evo Exhaust, ACT Stage 1 clutch W/ ACT flywheel, Apexi SAFC & Revspeed Meter, and many other toys.
Old 11-15-2002, 08:08 PM
I really couldn't tell you. I paid about $140 for the ring set. Luckily I have a buddy that has a shop and we did it there. I took the two of us all sat and sun to do it, not to mention the special tools you need plus a new head gasket. Giving the going rate for mechanics, I'd estimate you would be looking at close to 1000 bucks. If this is something that you just want to do and isnt really required at the moment, id save up and get new pistons and rods as well.
Old 11-16-2002, 03:05 AM
Sindonesia Sindonesia is offline
A cracked Head could be why the smoke is white, check and see if coolant is coming out of the exhaust. If this is the case don't buy the car.
Old 11-03-2003, 01:33 PM
whtcivic93's Avatar
whtcivic93 whtcivic93 is offline
Re: Why is it smoking?!
DAMN! 1000 bucks to replace piston rings... im in some shit.. i think mine are fried what usually causes them to get worn out or whatever?
96 GMC Jimmy black smoke, backfires, Timing? corhey88 Jimmy 38 01-31-2010 03:29 PM
91 Blazer Blows Smoke 91s10blazen S-10 6 11-25-2009 07:56 PM
Exhaust smoke lmattiso Rodeo | Passport | MU 2 11-23-2009 06:55 PM
88 IROC smokes after idling a few minutes.. IROCmenace F-Body Problem Diagnosis 6 10-13-2009 08:34 PM
smoking from the oil filler cap, dipstick and exhaust jimgbgt MGB 2 07-24-2009 04:26 AM
