Old 08-07-2007, 05:20 PM
granny_shifter's Avatar
granny_shifter granny_shifter is offline
factory alarm
i bought the factory alarm from my girlfriends dad, and i've been trying to install it today, but i've hit a possible problem.
i put in the ignition relay, spliced the power, added the ground, and i tried to start my car to see if i've made any mistakes yet and it won't start.
it's not finished just yet, so maybe i have to wait until its all finished?
has anyone ever installed the factory alarm themselves?
i fix things that aren't broken
Old 08-07-2007, 05:31 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: factory alarm
In my opinion you are wasting your time. The factory "alarm" is nothing more than a passive alarm. It doesnt go off unless the door in unlocked from the inside, or the hood is popped while the alram is set.
Old 08-07-2007, 06:09 PM
Re: factory alarm
i'm more happy to have keyless entry than anything. i got it for 20 dollars, rather than 250 at local places. i figured it would do for now.
Old 08-07-2007, 06:10 PM
Stealthee's Avatar
Re: factory alarm
what year is the car?If its post 92 you should have all the wiring and computer for the keyless, you would just need a remote to program.
Old 08-08-2007, 11:12 PM
Re: factory alarm
its a 96. theres no way to program the remote because there's no status LED/ override button.
i'm going to go over all of my wiring tomorrow, finish it up and see maybe if the in-line fuse is bad? maybe i wasn't getting a good ground connection.
my car is getting electricity to all of my necessary components, it's just not getting power to the ignition, and i'm sure the relay harness has something to do with that.
what would you say a life on a 20 amp fuse is?
Old 08-09-2007, 12:07 AM
Stealthee's Avatar
Re: factory alarm
A fuse is good till its blown.
This might help
http://www.3si.org/forum/showpost.ph...76&postcount=3
Dave is a master of 3s electronics.
Old 08-09-2007, 09:34 AM
Re: factory alarm
i pulled out the fuse, but i have no idea if its good or not.
i'm still going to check my spliced wires to make sure i have a good constant and switched power coming from the ignition harness.
i think i'll e-mail dave. thanks.
Old 08-09-2007, 12:01 PM
Re: factory alarm
ok, i got my car running, everything is wired great..
i'm still missing that LED/ override button so i can't program my remotes right now. i guess i could take it to the dealership but they don't really seem to know what they are doing there, last time i went there to ask them a 3000GT question.
suggestions?
Old 08-09-2007, 01:07 PM
Dave57's Avatar
Dave57 Dave57 is offline
Re: factory alarm
There’s no LED indicator/ override button, on factory alarms. There were some aftermarket alarms added by some dealers on cars with out factory alarms. Send me the vin and Ill see if it has a factory one.
'95 RT/TT Firestorm Red one of 61 MSRP $37,448.72 Digital Climate Control Conversion, DR-500 turbos, RPS, ARC-2,
03 Mitsu Infinity VRX System, Diamond D971 Components, JL e6450, JL W3.
Old 08-09-2007, 01:09 PM
Dave57's Avatar
Re: factory alarm
Wow Stealthee lots of posts!! opcorn:
Old 08-09-2007, 02:02 PM
Re: factory alarm
AGH i can't find the courtesy light wire. it says its a black/green wire in a 6 pin harness to the left of the steering column. i dont know where it is.
Old 08-09-2007, 03:46 PM
Dave57's Avatar
Re: factory alarm
The alarm in question is a Mitsu authorized accessory. That’s why there is confusion. This is for the cars without the factory alarms.
Car Alarm Types
There are two main types of car alarm activation methods. Passive and active. Passive alarms automatically enter an armed state after the ignition is turned off and the last door is closed. Active alarms require the user to press the transmitter button to arm and disarm the system.
