Old 08-07-2007, 04:52 PM
TommyWT TommyWT is offline
Airbag Cover Removal
I have a 2002 Alero. The upholstry that covers the passenger side airbag has come off due to sun exposure. I want to re-cover it but I don't know how to get it off. Any ideas???
Old 09-03-2007, 01:05 PM
figgepop figgepop is offline
Re: Airbag Cover Removal
No real reply but I'm in the same boat. I'll post if I come up with anything.
Old 09-03-2007, 03:17 PM
maxwedge maxwedge is offline
A990 racer
Welcome to AF. Look at holes in the side of the upper column shroud, there should be spring release clips recessed down in there, there is a special tool but but a long skinny blunted screwdriver should work, BTW the cover is part of the air bag! Double check my post the last one I did was a while back, look closely at this before attempting, also check into the precautions first.
Old 09-03-2007, 07:22 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
If you are asking how to remove the air bag you go through the glove box, remove that.
Then up, in the back are two screws holding it in.
Remove those, push it up through the dash.
AND as Max mentioned disarm the airbags!!!
I'd disconnect the battery and pull the fuse first.
Then unplug the pass side air bag via the fuse box(white connector).
Then you'll probly need some spray adhesive to reattach the new matterial to the cover.
GM realy did scimp out on the glues/adhesives in thier N body cars,
both mine GA's have some door peal goin on.....
1999 Grand Am SS 3.4 OHV
Old 09-05-2007, 07:16 PM
dugan50's Avatar
dugan50 dugan50 is offline
Authorized Vendor
xeroinfinity is right. The passenger side airbag removal is accomplished through the glove box and is very simple. The problem you are facing is that the cover is part of the airbag assembly itself and is molded, glued and shaped from the factory. Messing with them, voids their warranty (if any) and puts their operation at risk should you ever need it.
Disaable the system whenever you decide to work on or near it but I dont think you will be able to "unwarp" the damage done from years of sun and age
Good Luck
I hope this was helpful to you. My information comes from years of experience in these businesses.
http://www.airbagsolutions.com http://www.stolenandrecovered.com
Airbag Service, Airbag Replacement, Airbag Diagnostics
Thank You,
Douglas Gan
Old 09-05-2007, 08:30 PM
A990 racer
My error, I misread the pass air bag and gave instructions for the drivers side, thanks for the help xeroinfinity
Old 09-06-2007, 03:37 PM
handieeeeee handieeeeee is offline
I have the same problem on my 2000. If you can't put a new one on then what can you do?
00' Olds Alero
98' Dodge Intrepid ES
94' Pontiac Grand Prix SE
Old 09-06-2007, 06:27 PM
handieeeeee, which one the pass side ?
And one thing that didnt dawn on me is that if you cover the pass air bag it might not deploy when in a collision.
I have seen them recovered in black before,
though... they might have just used dye to color it...
I cant even remember where the split occurs on the pass air bag when it is deployed...
Old 09-07-2007, 09:12 AM
I thought about taping it off and just using a little spray paint on it
00' Olds Alero
Old 09-07-2007, 10:46 AM
They sell a liquid dye in different colors at parts stores.
Works much better on the dash then painting, paint just doesnt want to stick.
