Old 08-07-2007, 02:58 PM
peterbuiltman2001 peterbuiltman2001 is offline
Transmission - 94 Dodge Grand Caravan
while driving transmission shifts down into low speed and then won't shift back out.
Old 08-07-2007, 10:14 PM
ronmar1 ronmar1 is offline
Re: Transmission - 94 Dodge Grand Caravan
What type transmission? 3 or 4 speed?
Ron
Old 08-09-2007, 12:44 AM
tawnylee tawnylee is offline
Mine did this awhile ago, and was in fail safe mode. Something came unhooked. Sorry I can't be of any more help!
Old 08-09-2007, 06:13 AM
tempfixit tempfixit is offline
Doesn the shifter indicator say PRND3L? IF so it is a 4 speed transmission.
It is going into What is called the limp mode.
What engine?
How many miles?
Last time transmission fluid and transmission filter was changed?
Check transmission fluid level.
Make sure battery cable ends are shiney clean.
Check all grounds.
Check ground wire on transmission ( Look for a wire going to trans from wiring harness approxiametly in the strater area)
Check all connections to transmission input and output sensors for looseness or corrosion.
Check for moisture in the solenoid pack connector(This connector holds moisture, try and apply electronic grease to help prevent moisture build up.)
Use ATF +3 or ATF +4 Transmission fluid only
Look at these links for more info on trans:
http://www.allpar.com/fix/trans.html
Component Locations:
http://www.robskorner.org/faqs/Trans/a604trans33.html
Hope this helps
Old 08-11-2007, 04:59 PM
L,3, and D with push button overdrive.
Old 08-11-2007, 05:07 PM
3.0 v-6, fluid and filter changed twice in last six weeks. Nothing abnormal in pan either time. ATF plus 3. Mileage is 262,294.
Old 08-11-2007, 07:32 PM
Have you checked the transmission ground strap, was there any moisture in the solenoid pack connector?
You may need to go to a transmission shop to get transmission codes to help you out. Could be electrical or solenoid pack problems.
Old 08-15-2007, 03:23 PM
there was a small amount of transmission fluid.
Old 08-15-2007, 03:37 PM
Are you saying there was trans fluid in the electrical connector for the solenoid pack? If so is there a leaking cooler line. If there is any kind of fluiid in the connector clean dry and apply electronic grease as the moisture will cause elctrical problems<. I worked on a 95 that had moisture in there once cleaned and dryed it has not failed since.
