Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 08-07-2007, 01:12 PM
jpanisiak jpanisiak is offline
Exclamation Some problems
Ok, so i have a questiona nd a problem...
First off, how do you take the damn doors off of my jeep, its 2004 tj columbia edition. My manual they gave me is for a 2002 and it says nothing about the doors at all haha.
The other thing is when i am slowing down to a stop it sounds like the front end portion of my jeep rattles pretty loud right before i stop. Anybody have any clue what that might be? Im thinking something is loose for sure, i will take a look.
Any help is appreciated!
Thank-you
Old 08-10-2007, 11:28 AM
scoobytuff scoobytuff is offline
Re: Some problems
Do you know if the sound is coming from the brakes, or the suspension, maybe front diff? Also, is the Jeep a hard top or a soft top?
Old 08-10-2007, 06:10 PM
Re: Some problems
I think it is fomr the suspension, it sounds bigger than brakes, I have my hard top on it now. but the sound is there with the top on or off.
Old 08-11-2007, 07:16 PM
Kuhn's Avatar
Kuhn Kuhn is offline
Send a message via AIM to Kuhn Send a message via Yahoo to Kuhn
Re: Some problems
As for the doors... park your jeep down near my place in Detroit. Honestly, I'd be making it up if I told you how to do that, since I barely trust the Michigan weather enough to take the top off. I'm pretty sure it's just two bolts that hold each door on, though.
And the noise you are hearing could be a couple things. Do you have a manual trans? Do you have larger than stock tires? How many miles on it? Are there any problems with steering while braking? If you lift your Jeep and turn one wheel by hand and notice that the other is not (or that there's some play) then there is a problem with the steering. If it's not the steering, make sure it's not the brakes. After that, the trans...
It may just be normal, so I recommend taking it to the dealership... A sound clip might help me out, too! Good luck, and definately update the thread.
'98 Eclipse RS
ENGINE: Twin Ceramic Ball Bearing T3/T4 with ceramic blades (20G for sale!), FMIC, 3'' Intercooler Piping and Down Pipe, Dump after Down Pipe, Walbro 255 FP, 450cc 4G63 Injectors, Greddy E-Manage, TurboXS DSBC (4/7psi for now).
SUSPENSION: Sustec Front and Rear Lower Tie Bars, Suspension Techniques Front and Rear Sway Bars, DC Sports Front and Rear Upper Strut Tower Bars, Eibach Pro Kit Springs, KYB AGX Adjustable Struts, Polyurethane Bushings Everywhere.
Old 08-14-2007, 08:15 AM
BLAZERBOY69 BLAZERBOY69 is offline
Re: Some problems
Thank-you
NOT SURE ABOUT THE SOUND, NEED MORE INFO, BUT AS FOR THE DOORS, IF YOU LOOK AT THE DOOR HINGES, THE HINGE PIN SHOULD HAVE A NUT ON THE BOTTOM. TAKE THE NUT OFF, REMOVE THE SWING STRAP, AND LIFT.
