It's a Regency w/climate control. AC quit, so i checked R134a charge(converted). Charge is OK. but compressor won't kick on. Pulled some fuses to check them, now I have compounded the problem: Still no cold, but Climate Control Display blinks the outside temp for about 3 minutes after start up, and no AC symbol will show in any operation mode. First, any Ideas on how to stop the blinking, then, did i miss a fuse or relay somewhere? owners manual is no use.
JJP Big, Old, GM. |
Re: 92 98 AC compressor inop?
The blinking is telling you that there is a fault detected in the climate control system. There are two different systems in use, and each have different procede on how to access the self diagnostics which will give you readout code (on the climate control readout panel)
Please let me know if you have the dual zone or not and I will pass along how to access the codes. David |
Dual Zone it is.
Thanks for the reply.
JJP Big, Old, GM. |
turn ign on, no need to start engine. Press the OFF and Warmer buttons (on the HVAC system) simultaneosly and you should get a code readout on the face of the HVAC display. 00 - no codes present 10 or 110 - Amibient temp sensor circuit open or shorted 13 or 113 - In-vehicle temp sender open or shorted 15 or 115 - Solar sensor circuit open or shorted 35 or 135 - E&C Data line failure 38 or 138 - Serial data line failure with PCM 40 or 140 - Air mix door open or shorted 48 or 148 - Long term Freon loss 52 or 152 - Keep alive memory lost 66 or 166 - Low Freon Note that a number 1 prefix on any code indicates a history code. I hope this helps, I have spent more than a few hours on these nice, but somewhat troublesome systems. David |
