Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-07-2007, 09:50 AM
redrddvl redrddvl is offline
Ac Problems
I Have A 94 Caprice.recently My Ac Acting Funny .the Air Only Comes Out When I Have It Set On High When I Use The Medium And Low Switch It Dosent Even Work At All What Could It Be. But When I Put It On High It Blows Out The Cold Air And When I Use The Others No Fan At All
Old 08-07-2007, 01:30 PM
mike561 mike561 is offline
Re: Ac Problems
I had this problem on my 83, not sure how simmilar everything is though. at first i suspected the blower motor resistor, im not sure where thats located on the 90s caprices though. im sure someone will chime in though
2006 Chevy Cobalt LS
Old 08-08-2007, 02:20 PM
bubbba7778 bubbba7778 is offline
Re: Ac Problems
I Have A 2001 Tahoe, I Am Having Problems Of Course With The A/c, The A/c Works Fine When We Are Driving, But If We Slow Or Stop And Idle, The A/c Quits. I Was Watching The Rpm's The Rpm's Where At 450-500 When The Compressor Kicks In The Rpm's Would Jump Down, Then Would Jump Back To 450-500, I Was Told The Rpm's Should Be At 750, Can Someone Please Help Me!!!!!!!!!!
Old 08-08-2007, 02:53 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Ac Problems
Please Do Not Capitalize The First Letter Of Every Word You Type.
It Is Annoying.
Plus, post in the right forum. This is the Caprice forum, not the Tahoe forum.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-08-2007, 04:32 PM
btilley2006 btilley2006 is offline
Re: Ac Problems
Sounds like a resistor, it is located just below and to the side of the motor, it will look like a square flat piece of plastic with 4 screws (usually) and i connector. This is a Caprice forum but the tahoe could most likely be the IAC valve or one of the sensors seeing too much load and cutting off compressor to keep vehicle running, you might try cleaning the throttle body first.
