Old 08-07-2007, 08:42 AM
philipk65 philipk65 is offline
02 testing
What should the time intervals be between switching voltage?
How do I create a rich mixture for checking the 02 sensor high reading?
Old 08-07-2007, 09:14 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 02 testing
What year and engine?
What are you reading or testing them with?
MT
MT
Old 08-07-2007, 09:41 AM
Re: 02 testing
'91 4.3 L
I'm testing with a digital ohm/voltmeter.
Old 08-07-2007, 10:19 AM
MT-2500's Avatar
AF - Advisor
Re: 02 testing
Originally Posted by philipk65
'91 4.3 L
That one is a slow 02 sensor switching system.
With engine up to full tempt and on the road testing.
The 02 sensor should switch over and under .5 volts within a minute.
If over 2 minutes it will set a code.
At idle setting still a lot of them systems will drop out of closed loop.
The sensor has to be keep hot and at full engine tempt to work.
Pump the gas or pull map sensor vacuum and or unplug tempt sensor and you should see rich on 02 sensor.
Pull PCV valve and you should see lean on 02 sensor.
If not much switching under and over .5 volts and.
If the senor is old and never been changed you can put on a new one for 29.95 US $.
Are you having any engine running problems or codes or just checking 02 sensor?
MT
MT
Old 08-07-2007, 10:49 AM
MT-2500's Avatar
AF - Advisor
Re: 02 testing
'91 4.3 L
On any sensor testing you need to use a Low impendence volt/ohm meter.
The old resistor type will not read light computer voltage good and can even damage pcm.
MT
MT
Old 08-07-2007, 01:58 PM
Re: 02 testing
MT-2500, No codes and the vehicle runs fine, but I need it to pass smog so I'm checking everything. I wanted to check out to 02 sensor first, because to get this one out is going to be a chore!
I have a $50 digital volt/ohm meter. Is that low impedence? How do I check?
Old 08-07-2007, 07:21 PM
MT-2500's Avatar
AF - Advisor
Re: 02 testing
Hook it into 02 sensor wire and warm engine up good and read voltage.
Watch for switching over and under .5 volts.
MT
Old 08-08-2007, 11:40 PM
Re: 02 testing
MT-2500, I hooked up the digital ohm/volt meter to the 02 sensor and took it on the road and I got readings from - .20 - .92 volts. Switching back and forth everycouple of seconds.
Old 08-09-2007, 08:34 AM
MT-2500's Avatar
AF - Advisor
Re: 02 testing
It is working good.
Go ahead and have them do the emissions test.
If anything is not good it will show up on emission testing.
Good luck
If it is the 02 that came on it it could be a dirty or little weak or/off on 02 readings but still switching good.
If much off a good missions test will pick up on it.
I would make sure the plugs and wires and filters and base timing is good are good
MT
MT
