Go Back   Automotive Forums Car Chat > Dodge > Stratus
Old 08-07-2007, 01:16 AM
monzillaman monzillaman is offline
Unhappy ASD fuse blowing
I have a 1997 Breeze 2.0L that died the other day at an intersection (I know this is a Stratus forum, but the Breeze gets no love). Found a blown ASD fuse under the hood and replaced. Car ran normally for next 2 days (maybe 50 miles). Died again today pulling into a parking lot. Again, blown ASD fuse, however now the fuse blows the second you install a fresh one and crank the engine. I have swapped out the ASD relay just in case but did not solve anything. I'm assuming I have a short somewhere?
Does anybody know of any known issues regarding this problem or maybe can point me in the right direction?
Thanks for any help!
Oh yeah... what the heck is the function of the ASD system anyway???
Old 08-17-2007, 11:20 PM
canker4077's Avatar
canker4077 canker4077 is offline
Re: ASD fuse blowing
I dont know much about this either but i will throw you my two cents. My stratus horn/cig lighter fuse kept blowing it was a short somewhere I didnt need my horn that much so I never really got it fixed, but I would get yours looked at if it was me
Twinly
Old 08-18-2007, 03:00 AM
dsramprat's Avatar
dsramprat dsramprat is offline
Send a message via MSN to dsramprat Send a message via Yahoo to dsramprat
Wink Re: ASD fuse blowing
First of all, I want to say sorry for this lengthy reply.
This information is straight out of the 1997 Breeze/Stratus/Cirrus Factory Service Manual (Yes I paid the $90 for it years ago)
__________________________________________________ _______________
Automatic Shutdown (ASD) sense - PCM Input
The ASD sense circuit informs the PCM when the ASD relay energizes. A 12 volt signal at this input indicated to the PCM that the ASD has been activated. This input is used only to sense that the ASD relay is energized.
When energized, the ASD relay supplies battery voltage to the fuel injectors, ignition coils, and the heating element in each oxygen sensor. If the PCM does not receive 12 volts from this input after grounding the ASD reley, it sets a Diagnostic Trouble Code (DTC).
Automatic Shutdown Relay - PCM Output
The PCM operates the Automatic Shutdown (ASD) relay and fuel pump relay through one ground path. The PCM operates them by switching the ground path for the solenoid side of the realys on and off. Both realys turn on and off at the same time.
The ASD relay connects battery voltage to the fuel injectors and ignition coil. The fuel pump relay connects battery voltage to the fuel pump.
A buss bar in the power distribution center (PDC) supplies voltage to the solenoid side and contact side of the relay. The ASD relay power circuit contains a 20 amp fuse between the buss bar in the PDC and teh relay. The fuse also protects the power circuit for the fuel pump relay and pump. The fuse is located in teh PDC.
The PCM controls the relay by switching the ground path for the solenoid side of the relay on and off. The PCM turns the ground path off when the ignition switch is in the Off position. When the ignition switch is in the On or Crank position, the PCM monitors the crankshaft position sensor and the camshaft position sensor signals to determine engine speed and ignition timing (coil dwell). If the PCM does not receive the crankshaft position sensor and camshaft position when the ignition switch is in teh Run position, it will de-energize teh ASD relay.
The ASD relay and fuel pump relay are located in the PDC near the battery. The inside top of the PCD cover has a label showing relay and fuse location.
ASD and Fuel Pump Relays
The following description of operation and tests apply only to the Automatic Shutdown (ASD) and fuel pump relays. The terminals on the bottom of each relay are numbered.
| __85 ___________|
| __87A |87 |30 ___| Sorry for the crudeness of this. This is supposed to
| __86 ___________| be the relay terminals!
OPERATION
- Terminal number 30 is connected to battery voltage. For both the ASD and fuel pump relays, terminal 30 is connected to battery voltage at all times.
- The PCM grounds the coil side of the relay through terminal number 85.
- Terminal number 86 supplies voltage to the coil side of the relay.
- When the PCM de-energizes the ASD and fuel pump relays, terminal number 87A connects to terminal 30. This is the Off position. In the off position, voltage is not supplied to the rest of the circuit. Terminal 87A is the center terminal on the relay.
- When the PCM energizes the ASD and fuel pump relays, terminal 87 connects to terminal 30. This is the On position. Terminal 87 supplies voltage to the rest of the curcuit.
TESTING
The following procedure applies to the ASD and fuel pump relays.
(1) Remove relay from connector before testing.
(2) With the relay removed from the vehicle, use an ohmmeter to check the resistance between terminals 85 and 86. The resistance shoud be 75±5 ohms.
(3) Connect the ohmmeter between terminals 30 and 87A. The ohmmeter should show continuity between terminals 30 and 87A.
(4) Connect the ohmmeter between between terminals 87 and 30. The ohmmeter should not show continuity at this time.
(5) Connect one end of a jumper wire (16 guage or smaller) to relay terminal 85. Connect the other end of the jumper wire to the ground side of a 12 volt power source.
(6) Connect on end of another jumper wire (16 guage or smaller) to the power side of the 12 volt power source. Do not attach the other end of the jumper wire to the relay at this time.
WARNING: DO NOT ALLOW OHMMETER TO CONTACT TERMINALS 85 OR 86 DURING THIS TEST.
(7) Attach the other end of the jumper wire to relay terminal 86. This activates the relay. The ohmmeter should now show continuity between relay terminals 87 and 30. The ohmmeter should not show continuity between relay terminals 87A and 30.
(8) Disconnect jumper wires.
(9) Replace the relay if it did not pass the continuity and resistance tests. If the relay passed the tests, is operates properly. Check the remainder of the ASD and fuel pump curcuits.
I know you said you replaced the relay, and this is a test procedure for the relay, but I have bought bad parts in the past. The description before the test procedure at least gives you an idea of what components are wired through and controlled by the relay. One of those may be faulty. Email me if you want or need wiring diagrams and I should be able to scan them and email them to you.
I hope this helps.
Bending wrenches and turning air into the Sound Of Freedom!!!
Old 08-22-2007, 05:04 PM
I appreciate the replies! That does shed some light on the operation of that part of the system.
I was able to locate the source of the problem. I found a wire short in the harness to the right of the valve cover that leads to the number 4 injector. On the road again... for now.
Thanks again
