Old 08-06-2007, 11:45 PM
Dyno247365's Avatar
Dyno247365 Dyno247365 is offline
Graphics Card Overheating
I think my Nvidia 8600 GTS OC is overheating. It's locking up my computer games and causing my display driver to crash, and my computer turns out looking like some ripped 3,000 colors out of it. What should I do?
Another guy mentioned I should underclock it, and it would run efficiently, can I do this and how?
1996 Dodge Ram 1500 5.2L 5spd!!!
1987 Chevy Iroc-Z- -Needs a new cat
1992 Nissan 240sx 5spd- SOLD
Old 08-07-2007, 12:23 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Graphics Card Overheating
What are you using to monitor temps?
Your best bet is to throw another fan in your case if your overheating. Underclocking is an option, but I'd rather see you take care of the heat problem through ventilation. To underclock you should be able to use nTune and also monitor your temps since my guess is you have no idea what they actually are, your just guessing it's overheating.
http://www.nvidia.com/object/sysutility.html
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 08-07-2007, 02:12 AM
Dyno247365's Avatar
OK so I downloaded and installed Ntune and I'm looking at my Nvidia monitor. It shows my temperature GPU1 - 63 degrees Celsius. this is just running the PC, I'll try it when I run rFactor now...79 degrees Celsius and 45 Frames per second..I should be getting over 100
Old 08-07-2007, 08:16 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
Heat is definately the issue. Check the openings in your case for dust, cat hair, small children etc. and install another fan if needed. I'm running the same card, machine is overclocked and I have no problems, but i have 2 fans in the case and some custom duct work to channel the heat out.
Rusting out Honda Civic $900
Fart cannon muffler: $300
Assorted stickers advertising products you'll never own: $50
Having your @ss handed to you by a brick shaped suv: Priceless.
Yup, I own the suv.
Old 08-08-2007, 12:52 AM
Toksin's Avatar
Toksin Toksin is offline
Non-profit Organisation
Send a message via AIM to Toksin
Yeah, get some fans in there. Apparently the 8XXX's run quite hot.
Old 08-08-2007, 12:51 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
heat is not your problem, 73c is only in the 160f degree range.. No problem there. My card sees 180f most of the time when playing HL2 and such
Sounds like bad drivers or a faulty card, heat is deffinetly not the culprit
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
