Old 08-06-2007, 09:39 PM
ARoss052 ARoss052 is offline
Can dust damage my amp?
I noticed that my MTX amp was collecting dust and was wondering if that could damage it? Would it be ok if I blew out the dust with an air compressor?
Old 08-06-2007, 10:47 PM
AWP9521 AWP9521 is offline
Re: Can dust damage my amp?
Dust on heatsinks and what not can adversely affect the cooling of any electronic device when clogged with dust or dirt, if it is dusty inside and out I would NOT recommend using an air compressor to clean it, you can get water (from the humidity in the air) and or oil (from the compressor) on your parts and risk possible damage, plus the pressure is way too high, and could litterally blow components off the circuit board rendering your device useless.
If you need to blow the dust off on the inside or out, go get that liquid air in a can for removing the dust from computers, it still has some pressure when using the nozzle straw to blow off dust but is much safer for electronics as there is no moisture or contaminants, if your amp has a fan to draw air through it to cool down the inside components, stick something non metallic like a q-tip in the fan far enough to prevent the blades from spinning, do not allow the fan blades to spin freely when cleaning it, they are not made to spin at 10,000+ RPM.
Originally Posted by AWP9521 - 02/16/2005
Sure sex is a thrill too, but your modified car will never tell you
"Sorry honey, I just don't feel like it tonight" it will always be in
the garage silently waiting for you to hop in so it can thrill you
some more, that is unless you break it. At least they're easier
to repair and get the thrill back than a pissed off girlfriend.
