Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-06-2007, 05:46 PM
pharm_rodeo's Avatar
pharm_rodeo pharm_rodeo is offline
Replacing the overdrive pan gasket
It's only been a year since my tranny rebuild and the overdrive pan gasket is starting to leak. I tightened it as much as I care to.
http://www2.partstrain.com/store/pro...ls_and_gaskets
Does the above gasket look like paper to anyone? I sent an email to a local dealer to see what they have in stock.
Surfer is the only one I can recall that did replaced the gasket recently?
I assume that I would have to just remove the pan w/o draining any of the fluid out from the main pan. Install the gasket with some fluid and refill via the main.
I know most don't like to use any type of gasket sealer, but I might on the pan side just to keep it in place when bolting it down.
For some reason I don't think the shop replaced that gasket when the tranny was rebuilt.
1994 Acura Integra LS---212K+
1998 Isuzu Rodeo S 3.2L 2WD---176K+
Old 08-06-2007, 05:56 PM
FL 3.2L FL 3.2L is offline
Re: Replacing the overdrive pan gasket
Did mine in June. The one I installed was all black-like rubber. You can expect to have to catch a decent amount of fluid once the pan drops down. I was very messy, but you don't have to be! Just have a basin ready. As you probably already know, you don't need to torque those bolts very much or you risk tearing the gasket. I did that on the large pan. Good luck!
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 08-06-2007, 06:04 PM
I just read you changed your name. I was wondering who you were newb
BTW, you stated that you didn't change cylindrical filter screen? Debating whether I should order one.
Old 08-06-2007, 07:14 PM
I didn't change it because I couldn't remove the part I thought the filter was in. I still have the part. I have never heard of anyone changing it. I was hoping 2eye would eventually mention whether or not he has even changed one. It is accessed by dropping the main pan, though.
And I'd vote for no sealant. It's a small pan and gasket and its easy to get it in good position before tightening the bolts.
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
