Old 08-06-2007, 05:14 PM
Mangoamerican Mangoamerican is offline
Send a message via ICQ to Mangoamerican Send a message via Yahoo to Mangoamerican
clearing pcm
does anybody know how to reset the computers on a 04 cavalier?
Old 08-06-2007, 06:38 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
Re: clearing pcm
what exactly do you mean? clear the codes? like when your check engine light is on?? once the problem is fixed it will shut off on its own (with time) also, the same tool used to pull the codes will most likely clear the codes as well...
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 08-06-2007, 07:27 PM
Re: clearing pcm
no, thats not what i meant. i dont have any codes needing to be cleared, i just want the computer to re-calibrate itself
Old 08-06-2007, 10:08 PM
Re: clearing pcm
for what exact purpose? i cant think of why a pcm would need to be "recalibrated"....
Old 08-06-2007, 11:05 PM
Re: clearing pcm
well, id like to be able to reset it. if you could help me, that would be nice... if not don't bother replying, i can wait for somebody to explain it.
i want to reset the computers in the car after an oil change or any other maintenance so its not sitting in defaults
Old 08-07-2007, 09:03 AM
Re: clearing pcm
no one can explain it unless someone like me bothers to reply and try to get a little more info so EVERYONE can try to help you
if your talking about the 3000 mile countdown oil change thing, or anything liek that, that is most definetely not your pcm, there wouldnt be a need to "reset" or "recalibrate" your pcm, it does that kind of work on its own
Old 08-07-2007, 11:22 AM
Re: clearing pcm
anybody else? is there any way to clear the memory (not the programming) the stand by cache that it has learned in all your computers to make your car re-learn, i have tried unplugging the battery and cycling the key a few times.. then letting it sit for 30 mins, but it doesn't seem to reset - still cranks right up and the idle speed doesn't fluctuate - on my 97 you could really tell that it lost its information
