Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 08-06-2007, 04:04 PM
ProZach626's Avatar
ProZach626 ProZach626 is offline
Send a message via AIM to ProZach626
Vacuum Hose Leak?
I think I might have a vacuum hose leak. Many times when I press the clutch in, or take the car out of gear, the RPMs drop down to about 400 and the car feels like it's going to die. I hear a hissing noise, when driving down the road. I thought it was an exhaust leak, but I felt and listened for leaks and I have none. My MAF sensor has been freshly and safely cleaned and my CAI filter is 2 days old.
If it is a hose leak, whats the easiest and quickest way to find it? A friend of mine who used to work in a shop said spray the hoses with WD40 and look for bubbles, but that seems like it would take a lot of WD40 and a lot of time with the 20 different hoses in the bay......
All input is appreciated.
03 Molten Silve Spec V:Nismo SS;JWT BSR;Nismo CIA;Khumo Ecsta ASX Tires;Slotted Rotors;XS Header;Apexi WS2 Exhaust;Magnaflow Hi-Flow Cat;Nismo Coilovers;ESMMI;WRP IMS;WRP TBS;TB Port;WRP Grounding Kit
Old 08-06-2007, 08:15 PM
Toolman5523 Toolman5523 is offline
Re: Vacuum Hose Leak?
carb cleaner works best for find vacuum leaks.
Old 08-06-2007, 11:02 PM
Chiquae07's Avatar
Chiquae07 Chiquae07 is offline
Send a message via AIM to Chiquae07 Send a message via MSN to Chiquae07
sounds like a leak from your intake, before the maf, if that helps at all. that happened to me, as i instaled my aem cai, and had a small leak. i found it and problem solved.
2008 Mazda 6 ATX 2.3 Liters of Slowness
For those 9 seconds it takes me to reach 60mph, will be the most fun ill have in this car.
Old 08-07-2007, 11:45 AM
will1976 will1976 is offline
Or you can just ask a real man to fix it for you.
Old 08-07-2007, 12:12 PM
vgames33 vgames33 is offline
Didn't see that one coming
Old 08-07-2007, 12:15 PM
Chiquae07's Avatar
^^^lol. he got ya.
Old 08-07-2007, 03:34 PM
ProZach626's Avatar
Rofl yes! I was hoping you would say that, lol.
Old 08-07-2007, 04:51 PM
ProZach626's Avatar
Same way you use wd40?
Old 08-07-2007, 09:35 PM
no carb cleaner is flammable, so the idle would pick when you would over the leak (sort of like you just added a shot of gas). not sure about the diag about the leak before the maf, it would still be metered air. if that was the case you should only hear a noise, not much of a performance issue.
Old 08-08-2007, 02:11 AM
Chiquae07's Avatar
thats what i ment, sorry. after the maf. im still getting used to teh new laptop.
