Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-06-2007, 01:51 PM
deesandvees's Avatar
deesandvees deesandvees is offline
removing wheel wells 87 Caprice
I've got the motor out of my caprice and everything else hanging around the firewall and wheel wells except the heat/ac box and brake booster.
Can I easily remove both wheel wells?
The bolts all seem to be accesible but I don't want to run into any problems like not being able to pull them out once I've got it all unbolted. I want to strip them down and repaint. The battery side has some rust under wear the battery tray was (the only rust on this car thankfully). Since I've got the motor out I'm wanting to get everything nice and new under there, without having to take off the front clip or the fenders. Thanks.
Old 08-06-2007, 02:21 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: removing wheel wells 87 Caprice
Are you talking about the inner fenders? Yes, they can be removed without removing the outer fenders, but they have several bolts of two different sizes that will need to be removed, plus the battery tray on the passenger side will need to come out. You will need a 10-mm socket and a 13-mm socket.
If you want them to look new, see if you can find someone who can powdercoat them. This will give you the most durable finish for the engine bay, plus they will look good for a long time. You will have to completely devoid them of all paint and anything else beforehand, though. This usually involves media blasting (sand, soda etc). Don't forget to undercoat them once you reinstall them.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-06-2007, 03:46 PM
Thanks for the info, I'm gunna take a go at it later this week then. It'll be nice to be able to get at more of the frame too. I've seen the wheel wells chromed but that's too flashy for my tastes, I'll stick with getting them powdercoated.
no problemo
