Go Back   Automotive Forums Car Chat > Car Comparisons
Car Comparisons Compare any cars and find out what every body else thinks. Just refrain from making stupid comparos like Viper vs. Geo Metro :)
View Poll Results: Kung-Fu movies rock.
Ferrari 288 GTO Evoluzione 0 0%
Porsche 959 1 100.00%
Voters: 1. You may not vote on this poll
Old 11-12-2002, 05:51 PM
YellowMaranello's Avatar
YellowMaranello YellowMaranello is offline
Send a message via AIM to YellowMaranello
Porsche 959 vs. Ferrari 288 GTO Evoluzione
Well, what's your fancy? Both cars were way ahead of their times. Both are still considered mechanic marvels. Both are still considered extremelly fast and were released close to two decades ago. I personally would take the 288. Although I like the looks of the regular 288 much better. Here's some specs:
Ferrari 288 GTO Evoluzione:
Years of production 1985 - 1986
Numbers built 6
Body design N/A
Weight 940 kg / 2072.3 lbs
Drivetrain:
Engine 90º V8
Engine location Mid, longitudinally mounted
Displacement 2.855 liter / 174.2 cu in
Valvetrain 4 valves/cylinder, DOHC
Fuel feed Weber-Marelli Fuel injection
Aspiration Twin IHI Turbos
Gearbox N/A
Drive Rear wheel drive
Performance figures:
Power 650 bhp / 484.9 kW
BHP/Liter 227.7
Torque 667 Nm / 492.0 ft lbs
Power to weight ratio 0.69 bhp/kg
Top Speed 229.9 mph / 370.0 km/h
0-60 mph Acceleration 4.00 s
Porsche 959:
Engine:
Horizontally opposed 6 cylinder, 24-valve DOHC aluminum block and water-cooled heads
Bore and stroke: 3.74" x 2.64"
Displacement:174 cu.in. or 2849cc
Max boost pressure: 14.0 psi
Horsepower: 450@6,500 rpm
Power to weight ratio: 6.6 lbs per horsepower
Compression ratio: 8.3:1
Cd: .31
Fuel system: Bosch Motronic
Induction: Twin sequential turbocharging
Drivetrain:
6 speed electronically controlled 4wd with 4 settings
Suspension:
Electronically adjustable independent f/r with upper and lower A arms, hydraulic shocks, anti-roll bar/coil.
Body:
Kevlar and aluminum
Dimensions:
Curb weight: 2,917 lbs
Wheelbase: 89.4"
Length: 167.7"
Width: 72.4"
Height: 47.2"
Brakes and Wheels:
ABS, power assisted, vented, cross drilled disks
17x8.0" front,17x9.0" rear cast magnesium wheels with pressure sensors to detect hairline cracks
Fuel Economy:
13 mpg
Performance:
0-60mph: 3.6 seconds (US version: 3.5s)
0-100: 8.3
0-125: 12.7
0-140: 19.0
0-1/4 mile: 11.8s @119 mph
Top Speed: 198++ mph
Old 11-16-2002, 09:28 PM
No one has an opinion?
Old 11-26-2002, 02:58 PM
crayzayjay's Avatar
crayzayjay crayzayjay is offline
CFA
If its not a Japanese tin-box no one seems to care these days... this is Porsche and Ferrari's finest, people!
To answer your question, i'd have to take the 959.. ive always had a crush on it, and the 288 gto evo is just too ugly.. if it was the standard 288 gto it would be a lot closer... and if it was an F40, i'd be here all night trying to make up my mind
