Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 08-06-2007, 12:24 PM
chiefalex60 chiefalex60 is offline
99 4WD Indicator lites intermittent
In 2HI, the 2HI Indicator lite is on solid when I start, but soon goes out. Same if I put it in Auto4. If I push the switch again, the lite may come on while I hold the Sw, but goes out when I release. It transfers to 4HI or 4LO ok, but not sure about the lites on that side.
Old 08-06-2007, 02:12 PM
taillight taillight is offline
Re: 99 4WD Indicator lites intermittent
Sounds like a bad switch.
Old 09-17-2007, 04:08 PM
Scrooge McDuck's Avatar
Scrooge McDuck Scrooge McDuck is offline
Thumbs up Re: 99 4WD Indicator lites intermittent
Take the switch assembly out of the dash and open it up carefully. Take a small 'electronics' soldering iron and 'refresh' each solder lug on the circuit board of the switch by touching the iron to the lug just until the solder begins to melt. This happened to mine and I couldn't figure out what to do and didn't want to spend the $60+ that the dealer wanted to replace it. Then I remembered this same thing happened on my motorcycle with an air suspension controller. The solder lugs get corroded and become slightly loosened from the circuit board and cause this intermittent or complete failure depending which lugs are affected. Good Luck!
Scrooge McDuck
