Old 08-06-2007, 12:52 PM
dust2000 dust2000 is offline
99 Windstar problems after isolator bolt fixes
It all started with the water line under the intake leaking. It was recommended that isolator bolts and intake gaskets be replaced. I replaced these as well as plugs and wires since I had everything apart. Now with everything back together engine runs but idles rough. No power at all once you take off and tac jumps around inconsistently. Also hearing a thumping noise every once in a while on passengers side. Had no engine problems previously any ideals. Thanks
Old 08-07-2007, 02:54 AM
busboy4 busboy4 is offline
Re: 99 Windstar problems after isolator bolt fixes
Hi
Keeping it simple, my first thought would be to check for loose/disconnected vacuum lines. Not hard to miss one on the back of the plenum.
Good luck
Old 08-07-2007, 12:48 PM
AvalonJohn AvalonJohn is offline
dust2000,
Agree with "bus" check your vaccum lines. I did the fix last week and one of the lines fell off after I reconnected it. Also, check to make sure your wires for the plugs aren't crossed. I did that as well.
AvalonJohn
