Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-05-2007, 11:16 PM
chi-car chi-car is offline
97 Passport EX - Overheating Problems, Please Help!!
I have searched the forum, and read many posts. Hopefully some can give me an answer.
I tend to overheat in stop and go traffic. But on the highway or constant driving, I don’t seem to run hot. I currently replaced the thermostat (OEM Isuzu), water pump, upper hoses and Fan Clutch. The radiator has been flushed and replaced with new coolant. I don’t see why it’s still running hot. What can possibly be wrong now? Radiator? Please help.
BTW, I have a 97 Passport EX, w/108K 3.2L.
Old 08-05-2007, 11:20 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 97 Passport EX - Overheating Problems, Please Help!!
is the rad full? There could just be air in the system.
Or seeing that your rad is 10 years old it could be that too (I'm sure you read some posts, about folks doing the same steps that you have already, and it ended up being the rad).
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 08-06-2007, 12:58 PM
The Radiator is full. And based on the other threads on this issue, I followed the steps to remove any air in the system.
Old 08-06-2007, 05:36 PM
FL 3.2L FL 3.2L is offline
I'd vote for the rad, too, if you're sure there are no leaks.
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 08-06-2007, 05:41 PM
Ramblin Fever Ramblin Fever is offline
Park your truck nose up, take the radiator cap off (start with fairly cool engine), start the truck let it run for 10 minutes or so with heater on high - this will open the whole cooling system and allow for any remaining air to escape.
If you've already done this and it's still getting hot, have you also cleaned your radiator fins really well - lots of debris actually get caught in between the radiator & a/c condensor, causing overheating issues.
Could also be time to replace the radiator too; I have a 97 Rodeo and replaced mine end of last summer, starting to show it's age and blockages.
If you have not done so, your heater core hoses are most likely shot as well, passanger side near the firewall.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 08-06-2007, 05:54 PM
pharm_rodeo's Avatar
pharm_rodeo pharm_rodeo is offline
If you're 100% with everything you've done I'd say you need a new radiator. I've ordered from radiatorbarn.com in the past with no problems.
1994 Acura Integra LS---212K+
1998 Isuzu Rodeo S 3.2L 2WD---176K+
Old 08-15-2007, 08:48 PM
204beast's Avatar
204beast 204beast is offline
mine does the same thing too, i noticed that when it was doing that my A/C was on so i would hose it down with water(A/C rad) and the temp would go back to normal,so to fix that problem i installed an electric automotive fan on the outside of the A/C rad and now it acutually help in cooling and A/C is cooler now
