Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-05-2007, 08:54 PM
juniorts juniorts is offline
Exclamation need help w/ 1988 camry
Need help locating fuse boxes on 1988 camry especially fuses for windows and horn? ...
Old 08-05-2007, 09:05 PM
JOET/CAMRY JOET/CAMRY is offline
Re: need help w/ 1988 camry
I believe the fuses are located behind the drivers side kick panel. other fuses are located near the battery under a black plastic cover.
Regards,
JOET/CAMRY
Old 08-13-2007, 12:02 AM
nightmare84 nightmare84 is offline
There is a littlw panel on the drivers side kick panel with a little pull pin and that should open the fuse box for you and the window might be in there and the horn might be in the fuse box under the hood. Hope this helps
