Old 11-12-2002, 02:06 PM
Drinking straw exhausts INSTRUCTIONS
Well, i figured i'd do this so i don't have to email 1000 copies. Here they are, read them carefully:
Supplies:
-A large diameter straw
-A smaller diameter straw
-Crazy glue (hold best for these)
-Scissors
-Computer paper or maybe a little bit stronger paper
-Paint
1. Cut the big straw to a little smaller than an inch. This will be the exhaust can. Next, cut the smaller straw as long as you want, to form the tip. Look at the pics for reference.
2. Trace the circle at the end of the big straw on your paper and cut it out. This will be the top of the can, where the tip attaches. Put some glue on the edges of the cut out circle, and attach to the end of the large straw. You can put one on the back if you want. The circle in the picture is cut out, and the next picture is the completed exhaust can with the cap on. (I used the macro setting on my camera, but its still blurry in these, but you will get the idea)
3. Take the tip you cut from the small straw, and glue it to the top of the exaust can. Now all it needs is paint. Look at pictures below for reference.
Completed: (I used the yellow thing to hold it while painting)
If you need anymore help, or just want to say anything, post it! I hope this helps guys but don't forget that practice makes pefect. It took me a while to get these right.
Old 11-12-2002, 02:50 PM
primera man's Avatar
"P-Man"
Quite easy when you see how...yet so good looking.
Thanks for the thread.
View All My Models Here.
Old 11-12-2002, 02:57 PM
fullbloodchop01's Avatar
fullbloodchop01 fullbloodchop01 is offline
Send a message via AIM to fullbloodchop01
real good thread but can i ask what is the litle circuler thing between the can and tip is that the paper? if so how did u get it to be circle?
Rui
(modeling) = Click Here
Old 11-12-2002, 03:11 PM
TheSyndicate's Avatar
TheSyndicate TheSyndicate is offline
Full blood - he traced the circle on a piece of paper.
Old 11-12-2002, 04:08 PM
Exactly
Old 11-12-2002, 04:24 PM
what i mean is if u look at where the 2 pieces meet, where i have circled the edge is rounded where as if you cut a piece of paper wouldnt it be flat not rounded? just asking what ha did to get thet rounded edge effect or is it just the thicknes of the paper?:finger:
Rui
Old 11-12-2002, 04:51 PM
ales's Avatar
ales ales is offline
Forza Schumacher
Not bad. But there is room for improvemnet.
I suggest to eliminate the paper thingie (at least from the muffler side with the tip. Most of all because the one you made doesn't seem too stable and my guess is that a slight touch will rip the tip and/or the paper plug off. I would cut the thinner straw quite a bit longer so that it could be inserted into the thicker straw. Now the part of the thinner straw is wrapped in, e.g., masking tape so that the thickness of the tape + thin straw is the same as the inside diameter of the thicker straw. Now insert the straw wrapped in tape into the thick straw and glue it in place. You might aslo want to "plug" the end of the thin straw that goes inside the thick one so that you can't look oo far inside This version seems a bit more stable. Is anything I wrote here understandible at all??? Anyway, this should aslo work with aluminium/brass/wahtever tubing that you can get at your hobby store.
Oh, and RG, does your camera have a manual focus capability? You should be able to take clearer pics using that function.
Alex-the-king-of-long-replies
Old 11-12-2002, 07:15 PM
supratuner's Avatar
thanks for putting this up for now on i will be making a custom exaust for all my cas starting with the 300zx TT
Old 11-12-2002, 07:39 PM
Well, i figured out a soluion tonite. I filled the large straw with mounting putty (stuff you can put posters on the wall wiht, then inserted smaller straw. It holds it so much better and it doesnt fall apart as easily.
Old 11-13-2002, 12:34 AM
Talking
Thanks for posting this, I had no sucess with exhaust built from straws, but I'm going to give this a shot!
AF MODELING FAQ
"Oh what a feeling.- Toyota
Old 11-13-2002, 01:10 AM
magicmanjk808 magicmanjk808 is offline
Send a message via AIM to magicmanjk808
great post. thanks a lot.
Current Project:
Fujimi Toyota Altezza RS200
bye bye handles, moldings, rain gutters, license plate holders
View some pics of it here http://www.automotiveforums.com/vbulletin/t72123.html
Old 11-15-2002, 12:35 AM
Jonno's Avatar
Jonno Jonno is offline
Send a message via MSN to Jonno
What are you all, old and retired men?!?!?
I would't use the blu-tack (or poster mounting putty) because it doesn't exactly dry, and in the summer, it heats up and isn't as sticky. The answer to this....
tamiya putty!!!
Cheers for posting this...
-Holden Berlina Turbo, RB30ET.
-Mitsubishi Legnum VR4
Old 11-15-2002, 10:52 AM
hehe the tack stuff i use doesnt dry, but it is really stiff, and i dont have problems with it in the summer.
Old 05-12-2003, 09:20 PM
Lan_evo's Avatar
Lan_evo Lan_evo is offline
just woundering whats the size of the straw and where can I buy that. I Looked all over for straws but I cant find anything close to that.
Click Here
Old 05-12-2003, 09:27 PM
Camber's Avatar
Camber Camber is offline
Send a message via AIM to Camber Send a message via Yahoo to Camber
The canister of mine is from Arby's. The tip is a straw you get at the grocery stores in like the 200 packs
