Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 08-05-2007, 04:55 PM
Dell08 Dell08 is offline
Car Problem with 2000 Mist. Eclipse GT
The other night I was coming home. A car pulled in frony of me so I steered a hard left to avoid an accident. Now when I take a left hand turn I hear and feel a slight bump bump bump bump noise. I have been driving it around alot and it doesn't do it all the time, usually when I make more of a defined left turn than just a left hand turn. (if that makes any sense) Anyways if anyone knows what I am talking about PLEASE REPLY. THANKS!!!
Old 08-05-2007, 04:58 PM
G-man422's Avatar
G-man422 G-man422 is offline
Re: Car Problem with 2000 Mist. Eclipse GT
Sounds like a tire rubbing. Does your car pull hard left or right? An allignment will help if this is the problem.
Old 08-05-2007, 05:35 PM
Thanks for your reply!!! If you don't mind me asking was is tire rubbing. I just had my tire balanced and rotated, could a dramatic maneuver throw them off. And to answer your question it does not pull hard to the left or right.
Old 08-05-2007, 07:24 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
check your axle and tie rod, if either of those goes bad you will hear funny noises.
Don't act like you don't love it.
503/2000
Old 08-06-2007, 02:49 AM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
might as well check your control arm...if the ball joint starts to crap out the whole wheel will start to shimmy back and forth slightly and could make noise (also feel bad under braking).
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
