Cooling
Where is the coolant bleed screw on a 1988 4runner, 22R-E
Re: Cooling
There is no bleed screw
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html "What we've got here is a failure to communicate" |
Re: Cooling
K i wasn't sure. So if i drain the rad dont i have to bleed the air out now that i have filled it back up?
Re: Cooling
You fill up the radiator and overflow tank to the line. Then idle the engine until the thermostat opens up and you see the level drop. Then fill the radiator to the top and keep idling the engine until the radiator starts to overflow, then put the cap on and you're done.
Re: Cooling
Also, set the ventilation control to Hot and park the truck with the front uphill if possible.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs 80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ... 89 4Runner - stock 2000 Isuzu Trooper + 2010 Sonata |
