Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 08-05-2007, 04:18 PM
jonahj jonahj is offline
blower motor wont turn off
i have a jeep grand cherokee (1995, 5.2 liter) my blower motor wont turn off whenever i turn my car off, or when i turn it off from the dash console. whats wrong with it, is it the resistor? i can only turn it off by taking out the blower motor fuse. i need help please let me know? thanks
Old 11-02-2007, 10:13 PM
jburlin jburlin is offline
Re: blower motor wont turn off
Did you ever discover the solution to this problem?
Thanks
Old 11-04-2007, 01:09 AM
Bob D. Bob D. is offline
It's usually the control switch that gets too hot, melts slightly and causes the circuit to stay closed.
Old 11-08-2007, 05:42 PM
croozer croozer is offline
It`s the resistor under your heater box. Replace it.
Old 02-21-2008, 10:27 AM
psycho_maniac psycho_maniac is offline
Send a message via MSN to psycho_maniac Send a message via Yahoo to psycho_maniac
Could somebody explain more? How do you go about replacing the resistor? I have this same problem in my 99 WJ. Also Where do i get the parts from?
- Jerry
Old 02-21-2008, 12:43 PM
Look under the heaterbox on the passenger side below your glovebox. its about 4" X 4" square with a weatherpak plug on it. It has screws holding it on, Remove the screws and wire to take it out. The dealer will have the part for you. Its pricey, I`m not sure if local parts houses have this resistor. My wife works for the regional parts wharehouse for Chrysler/Jeep so it was easy for me to get it.
Old 02-28-2008, 02:04 PM
is there a fuse for the heater? i think i may have blown it because i took the resistor box out and when i went to plug it back in now the motor doesnt turn on at all. I would also like to add that I own a 99 gradn cherokee limited
- Jerry
Old 03-12-2008, 12:30 PM
tiffanysandoval tiffanysandoval is offline
GA_googleFillSlot("Forums_ROS_300x250_noad");I have a 94' Jeep Grand Cherokee with a straight 6 motor, I also have a remote starter in this also. Just recently I changed the oil pan gasket, now when i turn the car off the information display wont shut off and drains my battery... I tried taking out the fuse and when i do that my car shuts off. Also, my heater will turn on without the key in the ignition and I can put my windows up and down without the key in it... this car is posessed!! Anyone have any info.for me please!!
Old 12-28-2009, 06:41 PM
jeeper186's Avatar
jeeper186 jeeper186 is offline
I know this is an old thread. I am also having the same trouble with the blower motor not shutting off in a 98 JGC limited with a 4.0. I have replaced the control unit in the dash and the resistor next to the fan motor with no luck. Yea, I went to the recycle yard to get the parts thinking there cant be that many that would have the same problem. But I guess you never know. This one sure looked good when I inspected it. Wish I knew how to test the resistor. Just to many electronics inside. Could someone give more insight as to if I am on the right track? I am really getting tired of the hanging switch to turn it off and on. Thank in advance.
1947 Willys on Chevy frame, 350ci, 488 gears with detroits front and rear.
1997 JGC
1998 JGC
1995 JGC 7" lift 231 T-Case 33" tires.
Yes, I love JEEPS!
Old 12-28-2009, 08:41 PM
It is common that the resistor on the box goes bad. Replace it with new. Gambling with the scrap yard will most likely get you junk parts.
Old 06-15-2011, 02:49 PM
Biigpuker's Avatar
Biigpuker Biigpuker is offline
I too am having the same problem. I have a 99 limited with the auto temp control. So far I have ruled out the ignition switch. Now I am trying to locate the relay for the blower motor thinking this may have fused the tips together. I really hate taking it to the dealer but in a few days it's gonna get up in the 90's again. Anyone else have some idea?
Old 08-05-2017, 07:27 PM
96JeppOwner 96JeppOwner is offline
I know this makes no sense, but it is the blower resistor. Yes, I know it doesn't compute that a bad resister would deliver power to the blower with the key off and out of the ignition. My 96 Grand had the same issue and I figured it must be the relay (behind the glovebox on the end of a cable) - but swapped that out and it made no difference. I presented the problem to the Jepp Dealership mechanics ( 3 in the shop at the time) and they were stumped - suggested the 'electrical diagnostic test' at $135 for the first hour. Well, I bought the $200 Mopar resister and TaDa - everthing works perfectly.
