Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-05-2007, 03:11 PM
Wattsyurz's Avatar
Wattsyurz Wattsyurz is offline
Send a message via Yahoo to Wattsyurz
Mystery Motor
I have a motor someone built apparently using 327 heads with a 70's 350 truck block The cam is probably too big, because if the push rods get too close to the rocker, the valves are open way too long and I lose all compression. This leaves a very sloppy valve train. Does someone know if this could be corrected without removing the cam??
'67 Camaro 350 - driver, '83 Z28 305 (off the ECM), and T5
'91 RS 305 T5, 2000 C5 2000 Trans Am
I don't drive the Fords
Old 08-10-2007, 02:22 PM
Wattsyurz's Avatar
Re: Mystery Motor
Nobody wants to discuss this? The engine runs, but there's measurable distance between the pushrods/rockers. The cam is the mystery, the rest is given. Stock 327 heads, the same as the original 302. But a 350 truck block w/ hydraulic cam. I wanted to know about accomodating the cam that's in it. Measure the lift and make the heads correspond? Maybe I'll go ask one of those intelligent Advance Auto guys. (Shrugs)
Old 08-10-2007, 02:48 PM
Morley Morley is offline
Re: Mystery Motor
If there is clearance between the pushrods and rocker arms, the valve train is not adjusted right and I bet it makes all kind of noise when it is running.
Try here on how to properly adjust them http://www.centuryperformance.com/valveadjustment.asp
