Old 08-05-2007, 10:42 AM
ronkay ronkay is offline
92 GP LE A/C won't switch from floor to vents
AC will not switch from defroster to either floor or dash vents. AC cycles, fan works but air flow with not change. Recently had the car work on so I'm thinking it may be a vacuum line. Don't really know just guessing! Can someone help me locate the vacuum line on the 3.4 that controls the air flow direction? Is it possible the electrical switch could be bad?
Thanks for the help...
Ron
Old 08-05-2007, 02:50 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 92 GP LE A/C won't switch from floor to vents
That vacuum line runs off the block on top of the throttle body, over to the vacuum storage canister, then through the firewall to the HVAC unit.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 08-05-2007, 07:15 PM
Checked the vacuum line and all looks good? Any other ideas? Electrical perhaps. Is there a way to check?
Old 08-07-2007, 08:41 AM
richtazz's Avatar
Just for reference, what kind of work did you have done to the car?
Old 08-07-2007, 09:26 AM
After thinking about the problem I was convinced it was a vacuum issue and not electrical. Finally found a pinched line behind the motor. All is well and the system is working perfectly.
KISS - The simplest solution is most likely the best...
Thanks very much for all your help.
Ron.
