Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-04-2007, 08:55 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Slim Line Fan Performance
Well i wrote in a couple of months ago about my car overheating on the highway because of the FMIC. Did the fan rewire and that didn't help. So i just ordered two of the 12 inch slim line fans off of slowboys website. They say each one flows near 1200 cfm. Does anybody have any idea how much better this is to the stock fans?
Now since they are reversible, when hooking them up, should i have them pushing or pulling the air? A friend of mine suggested pushing towards the front of the car, but i would think that would just be taking hot air from the engine bay and forcing it through the radiator. I had planned on pulling the air from the radiator into the engine bay. Which one sounds like it would work the best?
Last question, do those 1.3 bar radiator caps work good like the vendors say they do? Can our coolant systems handle 19.5 psi when they come stock at 13 psi? Thanks in advance
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 08-05-2007, 12:15 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Slim Line Fan Performance
Dont make the fans push air through the radiator, not to sure about the other questions. I think people use 16psi caps but not sure about 19.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 08-05-2007, 12:24 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Kick your friend in the sack . Nah, you want them to pull for sure. Another thing you can (and should) do to help your cooling is duct the air better. Put up some plastic or sheet metal between the FMIC and the radiator to help keep the air from flowing out around and you should be good.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 08-05-2007, 08:04 PM
Yeah i figured the air should be pulled rather than pushed i just wanted to make sure. As for the ducting, ive been messing around with all of my old stock parts, to try to rig something up. No luck, but im sure ill find something eventually.
94 Talon 1.8L-SOLD
