Old 08-04-2007, 06:31 PM
Mar424 Mar424 is offline
Anyone know real watts of this amp?
http://www.onlinecarstereo.com/CarAu...roductID=18182
it says:
RMS Power @ 4 ohms: 4x55 + 1x220
RMS Power @ 2 ohms: 4x110 + 1x300
and other sites say different things, anyone have experience with it? or know how many watts i can expect for the sub channel? 300?
Old 08-04-2007, 09:57 PM
sickcallawayc12's Avatar
sickcallawayc12 sickcallawayc12 is offline
Re: Anyone know real watts of this amp?
depends on how you wire it to your equipment.
1998 Chevrolet Blazer LT (95% stock)
Pioneer AVH-P7500 DVD receiver
12" Alpine Type-R in a sealed box
PIAA Super Plasmas GT-X bulbs
PIAA Xtreme White bulbs
K & N drop-in filter
"Melo" and "AI". Enough said.
Old 08-04-2007, 09:58 PM
if i were to wire it to 2ohms..
Old 08-04-2007, 11:09 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Yes wire the sub into parallel, that will give you 2 ohms. Thats a nice little 5 channel, i have one in my girls car now.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 08-04-2007, 11:11 PM
but are those watts accurate?... or does it say 300 but really only gives 175?
Old 08-04-2007, 11:14 PM
alphalanos alphalanos is offline
It might be around 250 RMS @ 2 ohm due to the car not being a perfect 14.4V, if they tested it at that.
96 EJ6. Future home of boosted B18C1.
Old 08-05-2007, 01:17 AM
Mines pretty acurate. My MM75.4 tested at 249 with a dmm,@13.9v. They put out what they say. Its not pyle, or pyramid. And unlike hifonics these hit closer to there rated rms. And the 8k.5 in my girls car has the sub wired at 2ohms and with the car running, at 14.2v it has hit 300 watts. It also depends on the presets on the radio, and how you tune the amp.
But all in all autotek amps will put out what they are rated at.
Cardomain
Old 08-05-2007, 01:20 AM
what size/type sub is she using?
Old 08-05-2007, 08:16 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
autotek used to be awesome, haven't heard much from them lately
Old 08-05-2007, 11:19 AM
dbfreak147.5 dbfreak147.5 is offline
autotek will do rated power and then some!!!
2 Orion HCCA 10'S
2 AudioPipe 3k's
Adam Whitehead
Old 08-05-2007, 12:50 PM
Right now its a alpine type-r dual 4. Its the older one rated at 500rms. That thing hits pretty damn hard. Im getting a better sub for it soon. She wants to enter the car shows with me, so far i have built a custom enclosure with custom amp rack, and she wants a pink sub . Im doing alot to my truck now so im going to be really busy.
Cardomain
Old 08-05-2007, 01:01 PM
I was thinking bout getting a type-r but wasn't to sure because amp is rated 300 and the sub is 500, but since you've had good luck with it I might look into it more.
Any pics of the enclosure and amp rack?
Old 08-05-2007, 01:05 PM
I'm putting only 400 in my Type-R and it kicks butt. It doesn't rattle the neighbors windows or anything but is plenty loud in the vehicle and that is what matters.
Old 08-05-2007, 01:53 PM
Its a big misunderstanding but you dont have to run rms on sub to make it pump. But it is easier to clip the amp when you do that, so proper tuning is required.
My old subs had only 75 rms to each and i was able to kick 138 db out of them.
Il get some pics soon. Right now im building my new enclosure, for 2-15"s.
Cardomain
Old 08-05-2007, 08:30 PM
Audio Guy
the reason is that sound is on a logarithmic scale, not a linear one. If you double the power, you only get a 3 dB increase. If you double it again, you get an additional 3 dB. So the difference in playing an amp at 100 watts RMS and 400 watts RMS is only 6dB. The problem gets worse as the power increases - if your amp is 1000 watts, you need 4000 watts to get the 6 dB increase.
